door harness and more
Car: 1991 CAMARO RS
Engine: 305TPI SOON TO BE 350 TPI
Transmission: 5 SPEED
Axle/Gears: STOCK FOR NOW
im looking for the door harness for power windows locks and mirrors.
im also in need of a hatch pull down and poper wireing
im also looking for the power window arms that lift and lower the windows
and the power mirrors for both sides of the car
Car: 1992 Firebird v6 1992 formula v8
Engine: 3.1, 350 TPI
Transmission: both 700 r4
Re: door harness and more
I have a power window and locks harness from a 1987 iroc Z has motors regulators arms everything. Does not have power mirrors though. Everything worked great asking 25.00 plus shipping This would be everything you would need to convert your car to power set up except the mirrors
Car: 1991 CAMARO RS
shipping to 48173
Car: 1991 CAMARO RS
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Let me know if your interested in this Junction box: $10 + shipping.
I just installed an 87 Window / lock system onto my 91 set-up and having this Junction box made the conversion pretty easy. The 87 harness is not a "direct" plug in for the 91 cars......
Basically - you stick this box on behind the kick panel and plug the Power Window/Lock harness directly into it. Then you cut splice each of the 3 wires pictured into the plug coming from your 91 dash harness. Once the wires are spliced in just plug them into the and add a couple circuit breakers to your fusebox; Done.
But it from me or get it from "kurfbird"....... It will make things easier for you !
Also; I think the wiring is already in your car for the hatch motor and hatch "Pop" soleniod. You might just need to add a relay inside the center console along with the correct motor and button to get that system running !
