5-spd pedals?
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
5-spd pedals?
Don't know that I'd be able to buy 'em right away, but I'd like to find out how much I should expect to pay for a set of 5-spd pedals from a T-5 car... (And how hard are they to find?) Thanks guys.
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
Re: 5-spd pedals?
I just sold the pedals, switches and pigtails for $50 shipped. Ebay they run from $50-$90 shipped. Keep your eye on the Engine/Drivetrain parts for sale section on this site. They come up often. Pedals from a V6 are the same. I run into them at junkyards but, they are a pain to pull out there.
The master,slave, lines and heat shield will run about the same as the pedals. Make sure you get the heat shield GM has discontinued them.
From: South Bend Indiana iphone CALL OR TXT 574-607-2389
Car: 2003 GMC 2500HD Sierra Pickup
Engine: 6.0 Vortech
Transmission: 4x4
Re: 5-spd pedals?
I may be able to get em. Approx $90.00 shipped in U.S.
Ray
Ray
Re: 5-spd pedals?
Dokken10, thanks for the tips, I wasn't aware of the heat shield...
Ray, I appreciate the thought, but I think I'm going to try to find them for closer to $50 (no offense)...
Engine: 6.0 Vortech
Transmission: 4x4
Re: 5-spd pedals?
I just pulled a set a little while back from a 4th gen for a member here. Like Dokken said, they were a pain to pull.
Ray
Ray
Re: 5-spd pedals?
I'd probably do that, thanks. Do you have any pics? (Mostly looking to see how they are cosmetically, though I'm guessing I could get new/different pads for 'em...)
You wouldn't happen to also have the lines/heat shield, would you?
Thanks Zepher.
Thanks Zepher.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Re: 5-spd pedals?
Nope, all I have left are the pedals, bellhousing, flywheel, hurst shifter.
I'll see if I can snap some pictures of the stuff this week.
