Gauge Cluster for 91 Camaro w/ WHITE lettering...
Car: 1991 RS Convertible
Engine: 96 LT1
Axle/Gears: 3.45 9-Bolt
I know its not the right one for my car... But I prefer it. Anyone have one FS? Price shipped to 08053?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Gauge Cluster for 91 Camaro w/ WHITE lettering...
Was white even available 90-92?
JamesC
JamesC
Car: 91' Z28 1LE R7U
Engine: 350 ZZ6
Transmission: 6 Speed T56 Magnum
Axle/Gears: 3:42 posi G80/GU6
The GM white lettered ones were made in the 80's up to the 90 model year and are a different design completely. the 91' & 92's have Speed/RPM/Oil Pressure/Water temp/Volts/ & fuel. The 80's version is missing the oil pressure one. The 91&2s have all the gauges behind one piece of clear plastic while the older ones gauges are separated and each have thier own plastic cover. If you want different colours for your 91' you probably have to go to aftermarket specialty. The older ones would require you to to change the whole drivers side dash.
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
JamesC
Engine: 350 ZZ6
Yes I forgot, I went out back to look at my old 84' partsmobile, low and behold there it was in the tach.
From: South Bend Indiana iphone CALL OR TXT 574-607-2389
Car: 2003 GMC 2500HD Sierra Pickup
Engine: 6.0 Vortech
Transmission: 4x4
Both styles had only 1 plastic lens cover. The older version has a black plastic bezel separating the gauges for the driver so they really dont have their own cover. Someone makes aftermarket overlays for your current cluster and of course clusters as well.
Elephantismo
Feb 13, 2019 12:51 AM
1Aauto
Sponsored Vendors
Sep 13, 2017 12:58 PM
