[OR] 1982 Trans AM Automatic push button shifter (DONE)
Car: 1983 Pontiac FireBird S/E
Engine: '79 Pontiac 461
I am looking for the transmission shifter from a 1982 Trans Am (not the T version)
Got a shifter ****! no longer need.
Engine: LU5 305 CROSSFIRE
Transmission: TH-350
Axle/Gears: Limited Slip 3:23
Re: 1982 Trans AM Automatic push button shifter
Good luck on that. It's a KITT knight rider piece. Go for $100+ easy
Like that screen shot of Knight rider
Dave
Dave
Car: 89 Iroc Convertible
I have a 70-81 style shift **** with the Pontiac arrowhead button if your interested.Mounts up the same way as the 82 barrel style shift ****
Thanks, looks good.
I did get a lead on an '82 version. if it doesn't pan out, I'll let you know.
thanks for the offer
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Got the early thirdgen shifter ****, but not the shifter......
I am intrigued. Do you have a photo? how much would you be asking for it?
I'll pull it out and get you a picture a little later,.....just a little busy ATM. As soon as I've got it I'll post if here !
I'm unsure what year they are original too - but I pulled them both from 82's. Here is a couple pics of the 2 I've got:
The one on the LEFT is missing the little "Key" inside it that holds it in place on the shifter. You'd need to install a screw in the shifter under - or thru - the **** so it doesn't fall all the way down on the shaft. That one also has a button that faded.
The one on the RIGHT is in good condition with a good condition button.
I'm sure you know what these are worth. Expect a deal on the one to the left and a premium on the one to the right. if your seriously interested then send me a PM with an offer.
I thought it was pretty cool and wondered if it would fit our automatic shifters.
