Need a pristine HVAC housing. No cracks, missing pieces,etc. To fit a 1985 IrocZ. As you can see in pics mine is broken. Not worried about valves as they will be replaced. Need pics and price.
Here is one of the two I have out. This one, someone needed the cable- something easy to put on, if you have one. I also have another with cable attached, if you want to see pics of that, let me know. It was on a shelf above my head. Shoot me a message if you are interested in this.
Ok, brought them out. as you can see, one has metal and other has plastic round air vacuum pieces. The stems going into the air lines are thinner on the metal ones. The one has screw holes drilled in top cover, can be changed for the piece that doesn't, if you find that is the one you need. Hope this helps. Shoot me a message and let me know
