integrated dash display?
Old Jul 24, 2006 | 10:58 AM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
I was curious what you all thought about these systems: Pegasus - SPA Digital Dash Displays There are others there also..
They are pretty spendy.
Old Jul 24, 2006 | 10:59 AM
Badass_recaro's Avatar
Car: 1982 Recaro T/A
Engine: 305 w/Carter carb.
Transmission: TH-350
Axle/Gears: stock
NIIIICEE!!!
Old Jul 24, 2006 | 11:18 AM
Stealthy-One's Avatar
Car: 89 RS
Engine: 2.8
Transmission: 700r4 auto
Axle/Gears: huh?? guessing stock.
looks like what we run in Shifter Karts.
Old Jul 24, 2006 | 11:45 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I'd personally go for the real thing. , but they are 3X+ the price.
Old Jul 24, 2006 | 11:47 AM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
Hey Zeph, who sells those?
How are you doing, T/A is in little bitty pieces again.
Old Jul 24, 2006 | 03:24 PM
Zepher's Avatar
come on, take a guess at who makes them.
the steering wheel with mini-dash on it starts at $3499.
the other display is part of the Motec Display/Datalogging setup and I am not sure where that starts, probably in the $6K range.
MoTeC Advanced Engine Management and Racecar Data Acquisition Systems World Wide Directory
We have the LS1 motor here in the garage all in peices, just waiting to be assembled and installed. should put down 450rwhp easily.
What are you doing to the LT1?
Old Jul 24, 2006 | 04:54 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
youch pricey.. the question was who sells them, not who makes them smart***
the LT1 has Lloyd TFS heads, a Bret Bauer cam and converted supervic intake.. pics of the intake in the alternative F/I section if you take a peek.
Old Jul 24, 2006 | 04:56 PM
Zepher's Avatar
Well, you can buy them direct or from a dealer (not sure if direct is eventually through a dealer though).
Old Jul 24, 2006 | 06:52 PM
bjm323's Avatar
Car: '91 Camaro RS
Here is mine. I need to refine it a little more.
Old Jul 24, 2006 | 10:37 PM
J's T/A's Avatar
Car: 82 Trans Am
Engine: LTX
that looks pretty good! what setup is that?
Old Jul 25, 2006 | 03:56 AM
bjm323's Avatar
Car: '91 Camaro RS
Racepak Ultradash driven by Big Stuff 3 ecu.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
86IROC112
Nov 7, 2015 06:50 AM
Fanatic1074
Oct 2, 2015 03:47 PM
lewandom
Oct 1, 2015 08:15 AM
Eric-86sc
Sep 28, 2015 11:37 AM
