Center consold door panels
Old Aug 4, 2006 | 04:06 PM
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
How do I remove the center console and the door panels of a 84 firebird?
Old Aug 4, 2006 | 04:12 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
The center console is just alot of bolts. They are easy to find as you take it apart. The door panels have little plastic clips holding it in. You can get a tool to get them off at autozone. Be careful not to pull the clip out of the door panel. Most of the time the clips break when you remove them so pick up a pack when you get the tool.
Old Aug 4, 2006 | 06:06 PM
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
ahh ok I got the center console off I lost and broke a few things
Old Aug 4, 2006 | 06:08 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
What did you break and lose?
Old Aug 4, 2006 | 08:22 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
and in an early bird, the hardest oens to find the parts for usually
hmm thats crappy
what are you doing to it anyways
just curious
Old Aug 5, 2006 | 04:39 PM
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
replace carpet for a ligter cleaner carpet.
Im doing weight reduction
I broke a clip from the panel under the map pocket. and I lost the clip for the shifter
Old Aug 5, 2006 | 04:44 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
You won't lose much weight by replacing carpet, anyway the clip can be bought at any auto or hardware store, as far as the clip get one from a JY.
Old Aug 5, 2006 | 10:03 PM
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
yes I will Ill be removing about 4 inches of carpet I dont need around the console, and it will make the car look a little better
my86bird
Oct 23, 2015 12:20 PM
billybob6110
Sep 23, 2015 01:30 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
Out-Cast
Aug 23, 2015 06:33 AM
