What is this...
Old Aug 17, 2006 | 03:32 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
What is this...
This is some type of light under my dash but it is not very bright. It seems like it needs something else added. This is on my '92 and I am wondering if anyone else has one under their dash.
Old Aug 17, 2006 | 03:45 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It's to light up the A/C controls. It's not supposed to be very bright.
Old Aug 17, 2006 | 08:51 PM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
yeah i didnt even notice that one until 1year after i got the car lol
Old Aug 22, 2006 | 07:47 PM
matt_p's Avatar
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
There's a light there?
I guess I should put a bulb in to I can see my HVAC controls at night!
Old Aug 23, 2006 | 02:17 AM
Axle/Gears: Posi
Well it does not really light up the AC controls, at least not enough to notice. Thanks for the info.
Old Aug 23, 2006 | 07:10 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
It's only intended to cast enough light for you to be able to see the sliders in the dark. My Corvette has a small light in the bottom of the rearview mirror for the same reason, except that one's bright enough to dimly illuminate the whole radio/heater area. It's a subtle thing that you don't really notice until you put your hand over it and realize that everything just got darker.
Old Aug 23, 2006 | 08:55 AM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Mine doesn't work and I can't find a replacement. Any help?
Old Sep 30, 2006 | 09:35 AM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
im amazed at GM's concern. never knew about that light.
Old Oct 5, 2006 | 12:16 AM
Stealthy-One's Avatar
Car: 89 RS
Engine: 2.8
Transmission: 700r4 auto
Axle/Gears: huh?? guessing stock.
in mine the bulb is a standard 194. to get at it you have to take off the dashpad. at least thats how I got to mine. I put a super bright LED in there. But still cant see poo-poo with it.
Old Oct 7, 2006 | 11:33 PM
klause83z28's Avatar
Car: 83 z28
Engine: boat anchor 305 (ex CFI)
Axle/Gears: 3.23 10 bolt
I never noticed that light either. Is it on all third gens or certain years?
Old Oct 7, 2006 | 11:49 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Never noticed it....I now have the urge to go out and look at it!
Old Oct 8, 2006 | 12:59 PM
cfosceola's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
after reading this i had to go out and look and low and behold, i have light, this is my second camaro and i never noticed a light there, it even works.
Old Oct 8, 2006 | 03:09 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
firebirds have them too. both my 86 and 88
Old Oct 8, 2006 | 08:57 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Believe it or not, I read on another post about the same thing that it is called an ash tray light. Took mine out of my 92 RS and used the wires to gauge illumination (well, dimming for digital gauges).
Old Oct 9, 2006 | 12:49 AM
Denial's Avatar
Car: 84' z28
Engine: Built 350 SB 4 Bolt, Bored .30 Over
It doesnt look to stock.. i also have a 92 rs and its not on mine...
Old Oct 10, 2006 | 12:42 PM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
^^^Its stock^^^
My 89 has that but my 86 did not. The 86 had some sort of fiber optic if you will to channel the light from the bulb that lights up to shifter to light up the ashtray. So when I put the 86 Dash in the 89 I had to cut a whole to bolt up the little light. I was thinking about putting a LED in there and maybe it would light it up a bit because the HVAC controls are way to dim at night.
Mine went out a while back and I replaced it so the bulbs are available I just dont remember the bulb number off hand.
Kevin
92firebirdguy
Sep 1, 2016 07:53 AM
luvofjah
Sep 26, 2015 08:28 PM
Blue419
Sep 10, 2015 01:03 PM
Thaney9
Aug 7, 2015 08:25 PM
CD MaroMan 91
Mar 13, 2002 04:15 PM
