where to get clutch pedal pad?
Old Nov 8, 2006 | 12:09 AM
edman87k5's Avatar
Car: depends on the weather
Engine: several
Transmission: all manual
Axle/Gears: lots
Where could I find a new or repop clutch pedal pad and possibly brake pedal pad? Mine is kinda slick and my fat foot slips off if wet from walking through grass or wet. It is bad enough that the clutch and brake pedals are soo close together and sometimes when going for the clutch, I catch the edge of the brake too!
Old Nov 8, 2006 | 05:48 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Modern Day Muscle, a board sponsor. Should MDM not have them, PM me. I have a like new set.
JamesC
Old Nov 8, 2006 | 05:51 AM
diablo666mew's Avatar
Car: 89 camaro RS convertible
Engine: 305 tbi
look on ebay i have sean them on ebay to day sry dont no the link but aint aint to find
Old Nov 8, 2006 | 06:05 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Autozone, advance auto, napa, all sells them. Average price $3.99
Old Nov 15, 2006 | 05:45 PM
Roc Me 2's Avatar
Car: 1989 Iroc
Engine: In the works!!!
Axle/Gears: 9-bolt, 3.73 gears
Here you go.
http://cgi.ebay.com/ebaymotors/CLUTC...spagenameZWDVW
Old Nov 18, 2006 | 04:27 AM
edman87k5's Avatar
Engine: several
Axle/Gears: lots
The only ones I see have lines on them, mine has circles? The line ones are the same as trucks I think and can be had anywhere..
Old Nov 19, 2006 | 12:40 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I got ripped off then. I just bought one from Pep Boys today for $4.99. Pedal-Up brand, a division of HELP!, part number 20717.
Old Nov 24, 2006 | 11:25 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
You can still get them from GM. I picked up a new one from the dealership for $20.00 for my 84 T/A.
Old Nov 24, 2006 | 02:55 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Or you can get them from moderndaymuscle.com for $8 and are geniune GM parts.
Guess so... I am sorta looking for new pads myself... I am torn between the honeycomb or the lines.... functionality is my concern... It seems the lines would grip better, but my experience with them is that the lines are easy to fall off..
Old Dec 1, 2006 | 07:55 AM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
I bought an overpriced one from GM a few years ago because I wanted one with the original honeycomb pattern that would match the brake pedal pad, I had to order it and when it came in it didn't match even though it had the correct part #, it had the lines on it instead.
Old Dec 1, 2006 | 08:25 AM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
umm... modern day muscle.
Old Dec 1, 2006 | 09:13 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
any autoparts store that carries the HELP! brand has them... complete with the correct honeycomb pattern.
the clutch and brake pedal are the same, so just buy two.
Old Dec 1, 2006 | 09:24 AM
JamesC's Avatar
The clutch pad on my 85 is noticeably smaller.
JamesC
Old Dec 1, 2006 | 09:51 AM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
Yeah, my clutch pad is 3/4 the size of my brake pad.
Old Dec 1, 2006 | 02:13 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
heh.... i forgot something important...
uhh, i forgot i have 4thgen pedals... both of mine are the same size.
sorry about that..... but if you want, you can fit 4thgen pedals in, then run cheapo parts store padcovers.
Vintageracer
Sep 24, 2017 12:34 PM
loud91rs
Oct 5, 2015 10:05 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
mfp189
Sep 27, 2015 09:25 AM
ironbmt
Sep 27, 2015 06:00 AM
