i cant get the guage cluster out
Old Dec 25, 2006 | 02:12 PM
Yellow87Cam's Avatar
Car: 1987 camaro
Engine: 6 cylinder
Transmission: 5-speed
can anyone help me out real quick i got a ?
I have all the nuts removed, the 2 10mm nuts off, and it the guage cluster is loose but it wont come out...i cant find the speedo sending unit either, can any1 help me out? i wanted to take it out cause i got white face guages i wanna put in.
THanks,
Nick
Old Dec 25, 2006 | 03:23 PM
88KARRV6's Avatar
Car: All sold :-(
Engine: None
Transmission: None
Axle/Gears: None
I don't know why it's hung up in the dash, you should loosen the steering column bolts under the dash and lower it a little, that will give you more clearance to get it out.
If that doesn't help you might try taking off the dash pad and looking to see if anything is stuck on the back.
Old Dec 25, 2006 | 03:57 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
THanks,
Nick
The speedometer is holding it in place. You need to pull the cluster forward as far as possible, take a long flat blade screwdriver an push the locking clip on the back of the speedometer forward while pulling on the cluster at the same time. It may make it easier if you first remove the steering wheel, but it's not absolutely necessary.
Hope that Helps
Old Dec 26, 2006 | 05:39 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
ringo is correct. For removing the cluster itself, dropping the steering column a bit is helpful as is pulling the steering wheel down to its lowest postion. While you have the cluster out, consider repairing the odometer if it's broken:
https://www.thirdgen.org/forums/faq-...-fix-pics.html
JamesC
Old Dec 26, 2006 | 11:38 AM
Car: 1987 camaro
Engine: 6 cylinder
Should i disconnect the battery first? sorry that might sound stuiped but i'm new at working on cars and im not in the mood to get electricuted haha
Old Dec 26, 2006 | 11:52 AM
JamesC's Avatar
Always a good idea.
JamesC
Old Dec 27, 2006 | 09:05 AM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
it helps alot if you have real skinny hands, so you can feel around back there, it's intristing trying to find the clip W/ just a screwdriver.....having a kid W/ skinny hands really helps in this situation
Old Dec 27, 2006 | 09:11 AM
Stevo's Avatar
Car: Pair of 92 Z28s
Ya my skinny self was able to get my finger on the clip and press it forward then pull the cluster out.
Grab a flashlight too it helps.
Old Dec 27, 2006 | 09:30 AM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
So glad I have an electronic speedo
Old Jan 1, 2007 | 09:44 AM
Pat Hall's Avatar
Practice makes perfect. I've removed my instrument cluster so many times, I can locate and pop the speedo cable clip in a matter of seconds while half asleep these days! I've found it's easier to do with your fingers instead of a screwdriver since you can feel what you're doing. The first time was kind of a PITA, now it's a breeze to do. I have to disagree on the "thank G o d I've got an electric speedo" comment. I've seen so many 90-92 instrument clusters go screwy, it's not even funny.
Old Jan 1, 2007 | 12:25 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
just use a larger hammer
Old Jan 1, 2007 | 12:37 PM
klause83z28's Avatar
Car: 83 z28
Engine: boat anchor 305 (ex CFI)
Axle/Gears: 3.23 10 bolt
Yea I used a massive 1.5 foot flathead screwdriver.The thing is so big it wasn't useful for anything untill I needed it to get that clip off. Now that horrid christmas present from 2002 has use.
Old Jan 4, 2007 | 11:22 PM
turbochargedrs's Avatar
Car: Fire Red 89 RS
Engine: 2.8L :(
Transmission: 700r4 auto
the clip isnt hard to find and i didnt disconnect my battery and im fine. If you get under there with a flashlight and a screw driver over 10 inches you can get it in no time. all you have to do is find the cable and follow it back to the cluster. The real trouble for me came in not taking the steering wheel off i played with the stupid cluster for 20 minutes then decided i wasnt going to fight with an inanimate object anymore and started to pull the lights out and gave it one more shot and it came right out. i dont know what the issue was but if you dont take the steering wheel off you need to find the magic angle to get the damn thing out. (just take the wheel off)
Old Jan 5, 2007 | 02:28 AM
Pat Hall's Avatar
I've never removed the steering wheel to pull the instrument cluster. It's much easier to remove the underdash panel and undo the two 13 mm nuts that hold the steering column up. Once you undo those, you can drop the column down plenty far enough to pull the cluster right out. I hate pulling steering wheels and don't see the point unless you're tearing into the steering column for something.
Old Jan 5, 2007 | 02:52 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
The IROC steering wheel is easy to remove. Just remove the torx screws on the hub and it's off.
the RS wheels will need a puller though.
Old Jan 5, 2007 | 03:33 AM
Pat Hall's Avatar
Yeah, you got a point there. In fact, now that I think about it, I've got a Grant wheel on there now so I could do it that way too. I'm just used to dropping the steering column down. Habit I guess.
Old Jan 5, 2007 | 05:34 AM
JamesC's Avatar
IIRC, I was forced to use a puller to remove the wheel on my IROC. At any rate, like Pat, I've always dropped the column a bit, then adjusted the wheel angle. Whatever works.
JamesC
Old Jan 23, 2007 | 08:50 PM
TG Goose's Avatar
Car: 1985 Camaro Z28
Engine: 355 SD TPI
Transmission: 5spd w/Hurst Short Throw
Axle/Gears: 4th Gen 3.42 LS1 Brakes
If you remove the dash pad, is it easier to remove the speedo cable? I just tried to remove my cluster (85 Z28) and it doesnt move nearly far forward enough to get a single finger underneath it, let alone my entire hand.
Old Jan 23, 2007 | 11:46 PM
Pat Hall's Avatar
Not sure if removing the dashpad would gain you any more access or not. Never had to do that on mine. Usually once you undo the two 10mm nuts that hold the cluster in, just carefully and firmly pull the cluster back towards you. There's usually enough slack in the speedo cable to where you can pull it back a few inches or so to be able to reach the clip.
Old Jan 24, 2007 | 12:23 AM
TG Goose's Avatar
Engine: 355 SD TPI
yeah i think you missed the part where I cant even get a finger behind the guage cluster. Do i have to remove the underdash cover to get at all this stuff? or is that just to lower the steering column?
Old Jan 24, 2007 | 03:13 AM
Pat Hall's Avatar
Yeah you have to remove the underdash stuff so you can lower the steering column. There's the hard plastic piece right underneath the column that's held in by four bolts, then there's the flexible plastic cover that has the fuse panel door in it. Once you get those out of the way, just undo the two 13mm nuts that hold the column up. Once you get the column lowered and undo the two 10mm nuts that secure the gauge cluster, you'll be able to pull it out far enough to reach behind and unclip the speedo cable. You cant hardly pull the cluster out at all with the column up in place.
sheachopper
Jul 31, 2019 11:27 AM
