headliner building
Old Jan 19, 2007 | 06:55 PM
deadman's Avatar
Car: 89 camaro
Transmission: 700r4 w/ shift kit
Axle/Gears: stockers
headliner building
my headliner is sagging and i want to fix it. heres the twist im putting black interior in the car and need to make the headliner match .i thought of using the black carpet people use on speaker boxes. what do i do.
Old Jan 19, 2007 | 07:29 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
you can buy headliner material at most fabric stores. Most will have black in stock along with several other colors. If they don't have the color you want, ask if they can order it. That's how I got Charcoal colored material for my T/A. The 54" rolls they come in is wide enough for your headliner, I'd suggest buying 2 yards length. Ask someone there where their headliner material is and they'll actually know what you are talking about :-). It's felt with a 1/8" foam backing.
Be sure to remove all the old deteriorating foam from your current headliner board using a nylon bristled brush and use a good adhesive spray to attach the new headliner material. I suggest Permatex Heavy Duty Headliner and Carpet Adhesive. I got it at Autozone and it worked much better than the 3M stuff I had used previously. Once it makes contact, it won't release.... so be sure to set it right the first time.
Old Jan 20, 2007 | 11:06 PM
SS Ball3r's Avatar
they make fabric that has te foam backing so you can rip out all of the old healiner down to the very bottom?
Old Jan 21, 2007 | 12:05 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
I'm actually going to go get an old headliner (since I threw mine away) from a car at the boneyard and strip it, then cover it in duck tape. It'll only be a temporary fix since I'm getting tired of some of the rattle and the wires and bare metal. Ofcourse, its all in black. I managed to find black pieces for the interrior all I need is the carpet and door panels...
Old Jan 21, 2007 | 01:44 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
that's correct, and that's the only way to replace it properly. The reason that the headliner falls when it gets old is that the foam begins to disintegrate. When it does, there is nothing you can do to fix it for any significant period of time other than removing all of the old foam and installing new headliner material. Be sure to get the spray i recommended above, the stuff is awesome. after the new foam contacts the headliner board, it will not separate without tearing it to shreds.
and HCR13, spend the extra time and money to do it right since you're going through the trouble of getting a board and installing it. You can get the headliner material and adhesive for about $25.
Old Jan 21, 2007 | 06:22 PM
HCR13's Avatar
Car: 1987 Trans Am
I would, but this is only a temporary solution. I have a minor leak I need to fix first (I'm working on bigger, better things so I can't focus on the leak, and the weather isn't the best). I can get the headliner for about $5 and the duck tape under $6. I plan to get the abs headliner and interrior done in the Summer (when I can keep the t-tops off) I just need a temporary "metal/wire/rattle deadner", thus the quick solution.
Old Jan 22, 2007 | 09:23 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
If you've got a hardtop car, recovering your stock headliner is so easy that a caveman can do it.
However, if you have a t-top car, it's considerably harder because the material has no stretch to it, which makes it very difficult to wrap the inner curves around the t-top openings. I'm very experienced with wrapping all sorts of stuff in automotive carpet and vinyl, and I still screwed up my t-top headliner.
Unless you've done it before and you know that you're good at it, I'd stick with a new aftermarket headliner if you have a t-top car. If it's a hard top, it's easy to do and I wouldn't hesitate to recommend doing it. Do a search here and you'll find a bunch of tutorials on how to do it.
Old Jan 23, 2007 | 10:56 AM
Kenwood's Avatar
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
Best thing I ever did in my hardtop car was throw the whole headliner board away... Then I bought a ABS 1 piece headliner... I was lazy and had the local trim shop cover it***Mainly because I was deleting the factory belts**% point harness race/show car*** but either way that was YEARS ago and Ive not had any trouble at all out of it..
And yes the hardtop removal is easy enough for a caveman.. remove dome light bezel, remove sunvisors, remove rear hatch top halo trim piece and pull the headliner right out the back window area
Old Jan 23, 2007 | 11:47 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
where do you get an ABS one ? never heard of that before ? how much are they ? and are they worth the cost ?
also what would oyu use to repair any bad spots on the factory board ? like bad corner or bad area around the seat belt slot ?
fiberglass ?
or ?
and what if you live in a small retarded farming community where nothing exists cept a wal mart, how can you get headliner material ??
thanks
Old Jan 23, 2007 | 12:42 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
Try here, this is where I got mine and everything fit great.
http://www.hawksthirdgenparts.com/in...ROD&ProdID=621
Old Jan 23, 2007 | 12:55 PM
Kenwood's Avatar
Car: 1987 GTA
Transmission: th400
Axle/Gears: 9" ford
I got an UNCOVERED abs one...reson was As stated above I wanted to cover the stock seatbelt hole... Because my race/show car has 5 point harness in in... Id have to look at my receipt BUT the local trim shop bought it somewhere locally... I never made an appoitment.. I showed up to get a headliner done.. they left and came back 15 min later with an ABS BOARD if you will... It was made for the car.. I want to say it came from like Wilcox automotive.. >> then they put their own matching apholstry on the abs board..
But as posted above if you dont need anything custom places like hawks sell already apholstered ones**** However I have seen some of them come in multiple pieces... MINE was 1 Piece like stock.. so there is no seam..
Veaceonee
Sep 29, 2016 08:15 PM
PurelyPMD
May 5, 2016 04:57 PM
MORREALE5
Sep 13, 2015 09:01 PM
iroczguy86
Sep 13, 2015 02:22 PM
blackbmagic
Interior Parts Wanted
Sep 8, 2015 10:36 PM
