I need some carbon Fiber
Old Feb 14, 2007 | 12:38 PM
Moser's Avatar
[deleted]
Old Feb 15, 2007 | 10:44 PM
Kandied91z's Avatar
what exactly are your plans. the last roll i bought was $3,000. i've used two rolls so far on my interior and i have about a half a roll left to do. i also have 12 custom pannels though.
Old Feb 16, 2007 | 07:05 PM
ChillPhatCat's Avatar
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
j/k I don't think he needs that much carbon fiber.
Check out these guys: http://www.uscomposites.com/ You can do some smaller scale stuff for not tooo much money.
To build panels you want plain fabric and I read that Epoxy resin is the way to go in lieu of polyester which is normally used with Fiberglass. I'm not sure what weight fabric you'd want for interior panels... never worked with the stuff myself.
Old Feb 24, 2007 | 02:04 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
http://www.fibreglast.com/
Buy some while you can because..
prices are goin thru the roof and supply is hard to get because
1.govenrment is buyin the stuff up for F22 fighter jets
2.Airbus and boeing for the A380 and the 787
Do you want the LOOK of carbon? or do you just want Real Carbon to say you have it?
If its for strength use S2 fiberglass.
Old Feb 24, 2007 | 04:21 PM
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
The only functional use for CF is it's incredible rigidity and thus very light weight parts. If you just want the cosmetic look, you could buid parts out of Fiberglass and then just use a sheet of CF on the outer layer... that's how all the r!cer hoods are made.
Old Feb 24, 2007 | 06:16 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
The only way CF is lighter is if its layed up right and put in a autoclave to bake it. This give its strength and also squeezes all the excess resin outa the parts.
As you said if hes just fater the look just use Glass and get the sticky back CF look sheets.
Old Feb 24, 2007 | 08:49 PM
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
I meant that the stiffness allows for less layers to be used and that gets you a lower finished weight.
When you look at the specific gravity of FG vs CF it's like 2.8 g/cc vs 1.8 g/cc. So the density of CF is more than half that of FG whereas CF is about 4x as stiff as FG, so the extreme weight difference comes mostly from the added stiffness of CF.
Old Feb 26, 2007 | 11:42 AM
Kandied91z's Avatar
yep... this is a pain and also why it's so expensive if you go to have it done and as far as the rolls.. you don't get that much. it's really pricey. looks cool though.
grngryoutmyway
Oct 18, 2016 05:48 PM
Wylecoyote08
Aug 22, 2015 01:58 AM
CrazyHawaiian
Aftermarket Product Review
Jun 23, 2001 07:30 AM
91RedBigFinZ
Mar 14, 2001 11:38 PM
