Fixing a sagging sun visor...any tips? Done it before?
Old Mar 17, 2007 | 10:48 PM
Bazookajoe254's Avatar
Car: 86 Firebird
Engine: 2.8 V6
My driver side sun visor sags. It looks bad from the outside and annoying on the inside. It doesn't get in my view, I just like a clean interior. As messy as my room is, my car never has trash in it.
Anyway, as opposed to sitting like this: ((mount))=============
It sits like...
((mount))'''''''''''''------......... lol. ya know? sagging. sorry just felt the need for a horrible illustration.
any tips? the 3 screws holding the mount up are tight
Old Mar 18, 2007 | 12:01 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
I went to the junk yard and got the metal piece from a junker and and replaced mine and now it works just fine.
Old Mar 18, 2007 | 12:04 AM
91_T/AWS6's Avatar
Car: 91 Trans Am
If you look on ebay, someone sells the clips that go in the end of sunvisor so it is tight again with the bar that sticks in it. I think it was about 10 bucks. Mine kept flopping down when I hit bimps and these fixed the sagging problems.
Old Mar 18, 2007 | 05:20 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Ringo is right. Often the hanger itself is at fault. The bullet-shaped piece that the visor slides onto will have broken free from its housing and as a consequence rotates (when it should be stable). Under these circumstances, no amount of tightening the visor to hanger screw will eliminate the problem. A new hanger will fix the problem.
JamesC
Old Mar 18, 2007 | 12:08 PM
91_T/AWS6's Avatar
Car: 91 Trans Am
That's what the clips do that I bought. They slide into the end of the visor and the hangar rod snaps into them kinda like a bushing to take up the slack.
Old Mar 18, 2007 | 12:38 PM
JamesC's Avatar
If the hanger rod rotates in its housing, the clips/bushing will do no good.
JamesC
Old Mar 23, 2007 | 01:33 PM
slowmo2.8's Avatar
Re: Fixing a sagging sun visor...any tips? Done it before?
u know, you could always go onto ebay or Hawks third gen parts and find the whole setup/ junkyard is cheaper tho!
lol
Old Mar 24, 2007 | 07:37 AM
Meinherr49's Avatar
Car: 1988 Pontiac Formula 350TPI HARDTOP
Engine: 04- 350 Crate Motor with Crane Cam
Axle/Gears: 10 Bolt Posi 3.73:1
My Solution to a sagging sunvisor is this.....
Take off the Visor from the bullet shaped piece and wrap some Sewing Thread around the notched middle of it where the Screw goes to tighten it . The Thread gives the Screw something to hold onto and works Ok for me . A very Cheap Fix.
Old Mar 24, 2007 | 08:11 AM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Suppose the pin you're wrapping with the thread is loose in it's housing (the black triangle piece of metal that screws to the roof), which is why my sunvisor sagged. In that case your fix does nothing. I got a perfect replacement at the local junkyard for $1.00.
Old Mar 24, 2007 | 01:11 PM
Meinherr49's Avatar
What Evva...Eric.....")
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
92firebirdguy
Sep 1, 2016 07:53 AM
1MeanZ
Dec 18, 2015 05:39 AM
scotrans am
Sep 5, 2015 04:26 AM
