dash pad in 82 are diff
Old Apr 19, 2007 | 01:10 PM
carls1982z's Avatar
Car: 1982,Z/28
Engine: 355
Transmission: t350
Everyone at e bay says that 82--92 dash pads are the same, but did disagree.---i just received one for my 82 z/28 and it was out of a newer one ...and they come up short.---from windshield edge,, too edge closest too driver.---pretty sure 82 and 83 were thier own,----????? am i correct ???
Old Apr 19, 2007 | 03:38 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: dash pad in 82 are diff
Originally Posted by carls1982z
Everyone at e bay says that 82--92 dash pads are the same, but did disagree. pretty sure 82 and 83 were thier own
I think the designed was a bit different too. IIRC, those early years had a bit of a beveled-looking edge.
JamesC
Old Apr 19, 2007 | 04:16 PM
j dezzy's Avatar
Car: 87 TA
I'm not sure about camaros but 82-84 bird dash pads are different than 85-92. They are more square in the corners and have 2 lines running along the front. Here's a picture of the pad in my 84 TA...
Old Apr 19, 2007 | 06:24 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
The same is true for Camaros, but all 82-92 Camaro dash pads should work in all years. I had a newer one in my 82 and it fit just fine.
Old Apr 19, 2007 | 06:28 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I used a newer one in my '82 TA and it worked fine.. It's a slightly different style, but no one has called me on it. At least it's not cracked.
Old Apr 19, 2007 | 06:30 PM
j dezzy's Avatar
Car: 87 TA
85-92 style pads will fit just fine with no problems. and just like you said, chances are no one is going to notice. and if you want the 82-84 style be prepared to pay twice what you would for an 85-92 style pad.
Old Apr 19, 2007 | 06:36 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
On the '82-'83 camaro dash pads being different you're right.They have a similar more squared edge like the '82-'84 Firebirds.The difference being the Camaro's is done with simulated stiching.I have a dashpad out of a '85 in my '83 and it fits just like the original.I think the '91-'92 Camaro dashpads are somewhat different because of the redesign of the dash.
Carls1982z another possibility is they sent you a dashpad for a Firebird.The width on those is less than on the Camaro's.I would look at the Ebay ad to see how it was worded and contact the seller(just my .02).
Old Apr 19, 2007 | 06:41 PM
bluethunder28's Avatar
I think you're the one that asked question on my auction. The later pads will work just fine in the earlier models.
The main problem is that people advertise that the pads will fit both Camaro/Firebird. They're two different animals and won't work right and I *think* thats your problem that you are having.
Old Apr 19, 2007 | 11:26 PM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
Transmission: 700-R4
Axle/Gears: 9 Bolt 2.77
Yes, that is the problem with ebay...alot of stuff is advertised '82-'92 Firebird and Camaro. Over the years of owning my '82 TA I have come to know that the universal "82-92" wont always work.
The dashpads from all Camaro's should work with all years, same as the console, however they will NOT interchange with the Firebird. '82-'84 Firebird dash pads have the lines on the edge as someone already showed in a photo. '85-'92 they changed. All firebird dashpads will fit any year firebird. Unless you know the small differences between years, you can get the wrong information from unknowing ebay sellers.
Old Apr 21, 2007 | 01:05 AM
carls1982z's Avatar
Car: 1982,Z/28
Engine: 355
Transmission: t350
Thanks guys, I went back too e bay and the seller wont get back too me, figures !! havent used e bay much, so not sure what i can do as of now ??----As too the dash pad i got , he said it was out of a 86 trans am, and would fit the camaro,[ wrong] ---ANYONE NEED ONE FOR A GOOD PRICE. FOR A T/AM ??-------I RE,BID ON ONE out of a 91 z, i hope it fits if i win it.
Old Apr 21, 2007 | 07:39 AM
j dezzy's Avatar
Car: 87 TA
how much are you lookin to get out of the 86 pad?
Old Apr 21, 2007 | 09:11 PM
83camaroMN's Avatar
Car: 1998 Mustang
Engine: 3.8L V6
Transmission: Automatic with overdrive
Axle/Gears: 2.73:1 axle ratio
Yes 82-83 camaro dash pads were different styles personally I like the 82-83 pads better because they are thicker and have groves on the top. I have a dash pad out of a 86 camaro in my car right now it works but the style is g@y they are thin and crack way to easy. I also had a pad out of a 88 I think it was and for some reason it did not fit in my car so I am thinking any pad 88-92 wont fit right in a 82-87 camaro.
Old Apr 22, 2007 | 09:05 AM
carls1982z's Avatar
Car: 1982,Z/28
Engine: 355
Transmission: t350
YES, I PAID WITH SHIPING, 198.00 for the pad and ill let it go for ---110.00 plus ship.---thats a good price for what everyone else is getting.---but i have no use for it.---and as too the 82-83 pad, YES DEFF they were better and not so gay.-lol,----i got a bid on e bay now for one out of a camaro,[91]--if i win,, it better fit.---or does anyone one no something that hasnt been posted
Old Apr 22, 2007 | 09:17 AM
BBCFAN's Avatar
I have the same problem the dash I have is out of a 85-92 bird and has the removeable speaker covers it is about 2 inchs short for my 92 camaro. Sad because it is in great condition. What is the firebird dash worth what shoud I ask for it? Thanks Eric
Old Apr 22, 2007 | 10:01 AM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
For Firebirds there are actually 3 versions. 82-84, 85-89 and 90-92.
With the dash change in 90 there are slight differences in where the mounting bolts line up on the underside. As I remember 1 or 2 holes don't line up the same.
I have 2 excellent condition, 1 each of the 85-89 and 90 - 92 style sitting in my basement collecting dust.
PurelyPMD
May 5, 2016 04:57 PM
Billgluckman
Members Camaros
36
Nov 24, 2015 07:29 PM
FED 387
Interior Parts Wanted
Oct 10, 2015 01:43 PM
codeysabatini
Sep 20, 2015 11:36 AM
Stryker412
Sep 7, 2015 09:11 AM
