firebird dash in a camaro?
Old May 2, 2007 | 12:36 AM
KRACKER JACK's Avatar
Car: CAMARO RS
Engine: 3.1 V6,5.0 tpi
Transmission: AUTOMATIC, t5
Axle/Gears: one tire fire ,posi disc
i am sure it could be done does any one know how?
Old May 2, 2007 | 01:46 AM
VenomX-87's Avatar
Car: 1984 Trans-Am WS6
Engine: WAS: 5.0HO, SOON: ZZ383-425HP.
Transmission: 700R4 with shift kit
Re: firebird dash in a camaro?
aslong as it is the same year id say it would be a strait swap.
Old May 2, 2007 | 02:20 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
not quite.
the brackets to attach the dash to the car are different. i am sure somthing could be done, but you might have to cut the brackets out of a junkyard bird and weld them into your camaro. worth it? hell yes.
what is the same is the way the steering column and dash connect together, and that is some of your strength there. i also know there will be no problem physically making it fit. one thing to keep in mind however is that you will also need to switch all the vent ducting, perhaps even the entire heater box.
as far as the speedometer goes:
firebird switched to VSS in 1986. so if you have a VSS camaro (no cable for speedo, i think this is 90-92) you can use an 86+ firebird dash. if you have a cable you must use atleast the gauge cluster from a pre86 firebird. or convert to VSS.
good luck with your project. i can not wait to see the end result. if i ever own a Camaro i know i will do the same thing. i HATE the Camaro dash.
Old May 2, 2007 | 06:26 PM
lasher_350's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 9 bolt 327
I hate to be the one to say this, but if you hate the Camaro dash, why not just get a Firebird instead of a Camaro?
Old May 3, 2007 | 02:27 AM
Xophertony's Avatar
Axle/Gears: n/a
perhaps he hates the outsides of the Firebird (cant imagine why anyone would prefer Camaro over Firebird, but i am sure many of you Camaro guys feel the same way about the Camaro)
or perhaps he does not have the money to buy another car. or perhaps he just wants to do something different. i would like to own a Camaro some day, but if i ever do it WILL get a Firebird dash. even if i am the first person to ever do it.
Old May 11, 2007 | 04:59 PM
Car: CAMARO RS
hey thanks how hard will it be to cut the brackets im not supposed to have a saw in the junkyard.
Old May 13, 2007 | 01:36 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Ask the junk yard if they'll cut it for you. Some times they'll cut things off. Just tell them you need the brackets for your car because you're trying to fix something a previous owner did. Just make sure you don't drive the Camaro to the junk yard that day. Most junk yards I've found are accomodating if you ask.
Old May 13, 2007 | 02:23 PM
Xophertony's Avatar
Axle/Gears: n/a
you could actually get away with a cordless drill. you just need to drill some spot welds. that said, the one time i removed camaro dash mounts i used a sawzall. despite owning a firebird i do not know what the mounts look like, but i assume the mounts are attached in the same way.
Old May 21, 2007 | 05:03 PM
Car: CAMARO RS
i have the dash and the wire harness i now have an other problem i have a cable driven speedo tranny and an electric gauge is it easyer to swap the sensor or gauge?
Old May 21, 2007 | 07:44 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
in my 84 T/A, i've had 3 firebird dashes in it... the original, an 88 and a 91. There are differences in the bottom 2 mounts (near the kick panels) over the years, but the upper firewall mounts are the same. I've disassembled a camaro and the upper mounts all looked the same as those in firebirds. The bottom mounts from year to year aren't very different at all, easy to modify/bend.
I'm also using a diverter box from a camaro, and it's the same. The vents from the diverter box to the actual openings are dash specific, but the box is the same for camaro and firebird.
Old Jul 9, 2007 | 01:47 PM
Car: CAMARO RS
i got the dash in i had to replace the mounts but i looks decent thanks for the help.
Old Jan 27, 2008 | 06:28 PM
Car: CAMARO RS
now i am wondering about the wires are they the same?
Old Jan 27, 2008 | 06:36 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
why would you want to? bird dashes in third gens are quite ugly..
Old Feb 3, 2008 | 07:16 AM
Stephen's Avatar
Car: 87 GTA
That's a matter of opinion, and better left to yourself. It served no purpose to post what you did.
I think my GTA dash looks WAY better than my Camaros ever did.....again....MY OPINION.
Old Feb 3, 2008 | 07:59 AM
Jackthestripper's Avatar
Can't back up either one of your opinions, but the Firebird digital dashs are the ****.
Old Feb 3, 2008 | 11:26 AM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
it would probably be easier to do a camaro front clip swap onto a firebird with said dash
Old Jul 19, 2009 | 08:24 PM
Car: CAMARO RS
i got it done and it looks pretty good
Old Jul 19, 2009 | 08:46 PM
89RsPower!'s Avatar
post some pics!
Old Jul 19, 2009 | 09:03 PM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
I didn't do mine but I bought it like it. I think it looks pretty good. The speedometer was broken so I ended up putting a monster speedo in it.
Old Jul 19, 2009 | 09:22 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
^ love the speedo! Hmmm... tach next??
Old Jul 19, 2009 | 10:49 PM
JTNKTZ's Avatar
Engine: 355/350
That was the plan but I am going to sell the car...
Jorlain
Aug 24, 2022 05:11 PM
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Feb 4, 2016 07:10 AM
tnrednneck
Aug 13, 2015 08:57 AM
Vintageracer
Aug 11, 2015 08:13 PM
