B&M megashifter into an 85-92 TA
Old May 21, 2007 | 08:28 AM
j dezzy's Avatar
Car: 87 TA
I've done a search and read the other threads...but there seems to be one issue that hasn't been cover, at least not that I've found...Obviously with an 85-92 TA you can't use the shift plate overlay that is supplied with the shifter. I've read of people moding their console to ocomodate it....but, could I just instal the shifter assembly and use my stock boot and shift plate? Would there be anything in the way? would it shift correctly? thanks guys
Old May 29, 2007 | 03:39 PM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
Re: B&M megashifter into an 85-92 TA
i put in the mega shifter into my 88 t/a and i just trimmed out the stock shift plate first with the dremmel. i would think that you could use the stock plate without cutting but you would have to make your own boot or mod yours. the boot attachment on the b&m is rectangle. my shift plate was covered perfect and looked good but my console was falling apart. i just ended up putting in a camaro one piece console in. i have pics of both if you would like to see them
Old May 29, 2007 | 07:05 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
i would also be interested in the pix.
Old May 29, 2007 | 08:27 PM
j dezzy's Avatar
Car: 87 TA
I'd definatly like to see some pictures if you could post them.
Old May 30, 2007 | 03:39 PM
alright fellas since i am still new to this site i havent figured out how to get pics from my pc onto this thread.......but i did manage to get them into my vBGarage so if you just click on my garage i have six pix that i put together and here is what they are
1. shifter in car
2. relay in the lower middle of pic.
3. shift plate of trans am console cut
4. all done with t/a console.
5. i swapped in a camaro console
6. look at 5 for script.
Old May 30, 2007 | 05:43 PM
j dezzy's Avatar
Car: 87 TA
ok. looks like I can do what I'm looking to do. one more question. I'm looking at buying a used one from a guy on the board. he says that he has to give it a bit of a tug to get it in and out of gears...does this sound uncommon? or maybe it just needs some grease?
Old May 30, 2007 | 08:08 PM
when i got mine i bought it from summit and i ordered the 3ft. cable because i read on this site that the 5ft. one that it came with was really alot harder to get into and out of gear. i dont have much of a problem but it is new and a bit stiff. i personally think that it gives it a more manly feel. i dont think that it is to hard to shift though. my wife drives mine sometimes and she likes konwing that the tranny is definitely in gear.
Old May 30, 2007 | 09:34 PM
j dezzy's Avatar
Car: 87 TA
ok. speaking of cables, will the stock cable work with it?
Old May 30, 2007 | 10:05 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
J-Dezzy, i would very much like to keep my shift plate as is, without cutting it up. However, i LOVE The megashifter boot, so if you could some how get the shifter in place with your stock shiftplate unmodified, please post some pix.
Btw, are you buying Badman's shifter? If so, they are not quite the same.
Old May 30, 2007 | 10:47 PM
j dezzy's Avatar
Car: 87 TA
BADMAN has a sale pending on his right now. So I'm looking at one from another guy too. both are the same price, so it's all in who can hook me up first...what do you mean that they aren't quite the same?
Old May 31, 2007 | 04:12 PM
no the stock shift cable doesn't work with it but the b&m set up takes oll the plastic clips and stuff out off the mix
Old May 31, 2007 | 04:15 PM
j dezzy's Avatar
Car: 87 TA
ok. I pretty sure the guy that I'm buying the shifter off of has included the cable. just wanted to know. thanks. I am determined to make it work with my stock console setup. I'll post pictures once I'm done working my magic. lol.
Old May 31, 2007 | 08:18 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Jdezzy, i think Badmans shifter is a different style, or just really really old. It still works fine i think, but u may run into some probs when shopping for parts with his.
Old Jun 1, 2007 | 03:42 AM
j dezzy's Avatar
Car: 87 TA
I ended up going with another one. BADMAN didn't get back to me fast enough on weather he sold it already or not so I picked one up form another guy.
Vintageracer
Sep 24, 2017 12:34 PM
jerflash
Sep 23, 2015 09:21 AM
unknown_host
Aftermarket Product Review
Aug 11, 2001 08:44 AM
jimbo
Mar 14, 2001 05:35 AM
STL1994
Feb 17, 2001 02:41 AM
