Vats Steering Column Replacement
Old Jun 11, 2007 | 09:54 PM
BlueSmoke's Avatar
Car: 91 RS Camro Ttop
Engine: 5.0 LO3
My steering column' tilt mechanism is broke, turn signal/ dimmer switch is broke and key switch is on it's last leg. I had purchased a floor mounted dimmer switch as my headlights are now stuck on high, and that's a ticket waiting to happen around here. Then the turn signals gave out and I'm bald or I'd be pulling my hair out at this point. My 87 column is in perfect appearance and working order. My problem obviously is vats. How can I install a non vats unit into a vats equipped car?
Old Jun 11, 2007 | 10:28 PM
MNformula350's Avatar
Re: Vats Steering Column Replacement
You shuold just be able to install the key lock cylinder into the 87 column and run the wires down through the column like a normal vats column. The vats interrigator box is under the dash anyway.
Old Jun 12, 2007 | 09:24 AM
BlueSmoke's Avatar
Engine: 5.0 LO3
The vats keyswitch is in bad shape. Is there a way just to do the swap and bypass/remove the vats.
Old Jun 12, 2007 | 08:45 PM
BlueSmoke's Avatar
Engine: 5.0 LO3
anybody??????????
Old Jun 12, 2007 | 10:03 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Measure the resistance between the key contacts and get a resistor close to it at Radio Shack. Add the resistor in the circuit by cutting the two small wires that go to the switch. This will eliminate the protection of course.
Good read here:
https://www.thirdgen.org/vats_passkey_system
Jorlain
Aug 24, 2022 05:11 PM
Out-Cast
Mar 22, 2019 09:39 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
evilstuie
Feb 28, 2016 03:33 PM
Bull86
Aug 10, 2015 05:43 PM
