a couple pics of my finished vinyl seat kit from hawks
Old Aug 6, 2007 | 07:18 PM
stagefright4's Avatar
Car: 1992 trans am tpi 350
Engine: tpi 350
tell me what you think
Old Aug 6, 2007 | 08:54 PM
mlaskow86's Avatar
Car: 1989 Trans Am
Engine: 5.0 TPI
Transmission: 5 Speed Manual
Axle/Gears: Stock Rear End
Re: a couple pics of my finished vinyl seat kit from hawks
dosnt look bad but the fronts look a little loose.
Old Aug 6, 2007 | 09:34 PM
Engine: tpi 350
yeah i the fronts were being stubborn, but doesnt look bad for my first time.
Old Aug 6, 2007 | 10:21 PM
83Chevy__Camaro's Avatar
the back seats look great, should tighten up the front seats if you can and it would look new, other then that great job
Old Aug 6, 2007 | 10:36 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
What did you pay for that kit, if you don't mind me asking?
Old Aug 6, 2007 | 11:15 PM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Looks nice and good job on 1st try. Fronts could use some more finnesing. The double stitching is nice and looks better than the old tube run seam. Looks kinda like leather
Old Aug 6, 2007 | 11:22 PM
2tonedmaro89's Avatar
Car: '91 RS
Engine: 5.0L gross *** tbi
great job for a first time... i would still see if i could tighten the front seats a lil more
Old Aug 7, 2007 | 12:00 AM
Engine: tpi 350
yeah i agree with everyone on tightening the fronts, shouldnt be too hard i was in a rush cause i needed them back in the next morning since its my D&D. also i got the kit from hawks for $349 shipping included.
Old Aug 7, 2007 | 12:28 AM
Duratys's Avatar
Car: 91GTA 89TTA
Engine: 305 3.8 Turbo
Transmission: MK6 2004r
Axle/Gears: G80 3.42s 3.27s
$350 dosent sound all bad for how that looks Take a couple days off before you try and remove the larger wrinkles........always seems that stuff goes better after a couple days off.
Tys
Old Aug 7, 2007 | 12:47 AM
Engine: tpi 350
yeah ive got tuesday and wednesday off till i start my new job so it will look better by tommarrow
Old Aug 7, 2007 | 11:21 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
looking good, not a bad price either.
Old Aug 7, 2007 | 11:55 AM
Joker1232's Avatar
Car: 92 Z-28 "Z03"
Engine: 5.7L TPI
i have the same problem w/ my seats...i recovered them also. They are loose because i have read you are supposed to hit the seats w/ steam and it will begin to loosen up the foam. The seat covers i guess you are supposed to do the same with to lossen them up....i tore my front seats a lil on the back @ the seams but you cant tell after a lil stitching. My father says they will tighten up after a while out in the sun...from expanding and contracting from the hot and cold
Old Aug 17, 2007 | 06:32 AM
3rdGenWillie's Avatar
Car: 92 Lo3 RS
Engine: 305 roller tbi
Transmission: t-5
Axle/Gears: 3.08 open
actually steam is the key or if u dont have a steamer a heat gun and water gets the same effect. in the interior business they use a steamer with a long thin wand of copper so u can get up in the set. if u cant steam your old foam buy some more from a int. shop 1/2 " will do most time. but concentrate on the front and sides not back, head rest will also have to have fresh foam on top they are made of more dense material and will not puff much with steam.......any more ? been there done that have the mental scars to prove it......custom fab hot rod interiors is a varied discipline but u can do it
Old Aug 17, 2007 | 09:33 AM
Rick Routzahn's Avatar
are they leather, leather-look , or vinyl??
colton_carlson
Mar 8, 2019 12:21 PM
Cleotiz
Jan 6, 2018 08:56 PM
Linson
Aug 21, 2015 02:12 PM
Mister_Johnny99
Interior Parts Wanted
Aug 14, 2015 12:59 PM
drathaar907
Aug 6, 2015 04:20 PM
