heat coming thru the floorboards?!?!?!?
Car: 1987 Camaro
Engine: 350 dart ies comp cam intake carb
Transmission: 700 r4, shift kit, 2400 stall
Axle/Gears: 10 bolt stock
anyone having any problems on their thirdgens with heat coming thru the floorboards, on my car there is heat coming thru the floorvents and it seems to come when you start moving the car, the ac is completely taken out and i made a piece of steel to cover the place where the ac condensor was, i also dont have a heater valve on my heater core lines, anyone have any suggestions or the same problem or a way to solve it?
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Re: heat coming thru the floorboards?!?!?!?
Are you talking from the actual floor?, or from the vents near your knees. Is it only when you move, does it start right away? all are questions we can use.
Car: 1987 Camaro
ok the air is coming thru the vents, and it only happens when the car is moving and slightly coming thru when the car is stopped
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
get rid of the heater core. It's not doing anything but throwing off heat the way you have things set up. Also you might as well get rid of all the ducting behind the dash too.
Car: 1987 Camaro
oooo idk about that this car is my daily driver and i really like that heater during the winter hear in kansas
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Definitely don't get rid of the heater core- no more driving at night or when it's rainy and the windows fog up either. I think they all have this problem- some just notice more than others.
Car: 88 IROC
Engine: 5.7 RamJet
Maybe I'm not following what you did.. if you removed the part where the AC was and put a steel plate over it, then you no longer have a fan.. so there's not much going to happen as far as moving the hot air when you want to.
Try moving the control to MAX AC and then the hot cold to cold. That should close off most of the air flow from outside and push less air through while driving.
Car: 1987 Camaro
hmmm, well the hole in the heater box where the ac condensor was is covered with a sheet of metal, the heater still blows hard and fine, but the floor vents let air thru when i have the heater turned to off, but if i turn the heater or ac on anything else the air comes out of vents or defrost
really confusing?
really confusing?
Car: 88 IROC
Engine: 5.7 RamJet
Ok so you left the housing there. I thought you meant that you put a piece of sheet metal on the firewall to cover that hole.
Car: '89 Firebird Formula
Engine: 305 TBI
its doing what its supposed to, there is no 'off', you will always have a litle bit of forced air
and you removed the shutoff valve to the heater core, so even on full cold your heater core will be warming up, therefore all is normal
kyle5647
Aug 15, 2015 11:56 PM
