Turn signal broken...
Old Aug 28, 2007 | 10:24 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Left turn signal works fine, but when I click it up to turn right it goes all the way up, doesn't turn on, and immediately falls all the way back down. How can I fix this?
Old Aug 28, 2007 | 11:12 AM
strokermotor91's Avatar
Car: 91 Camaro RS
Engine: Small Block
Transmission: TH350 w/ 3000 stall convertor
Axle/Gears: 3.73 w/ powertrax locker
Re: Turn signal broken...
get yourself a new turn signal switch, it only takes about a hour to install with the correct tools.
Old Aug 31, 2007 | 05:34 PM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
the hard part is to take off the snap ring around the lock plate. major pita
Old Aug 31, 2007 | 08:57 PM
Car: 91 Camaro RS
Engine: Small Block
Go down to your local parts store and get the tool. They make a special tool for this. it costs maybe around 10 bucks. Makes life so much easier. I did it before, without the tool and it took me(by myself) like 4 hours to remove and replace. Good luck though.
Old Aug 31, 2007 | 09:24 PM
kuulkatdadieo's Avatar
Car: 1989 Pontiac GTA
Engine: 350 5.7 T.P.I.
Transmission: TH 700-R4
Do you know what it is called??
Old Aug 31, 2007 | 09:35 PM
Car: 91 Camaro RS
Engine: Small Block
steering wheel lock-plate remover and installer. that is the correct name for it. Makes everything so much easier
Old Sep 1, 2007 | 01:38 AM
Mylilbowtie's Avatar
Car: 1988 Iroc-Z / 1992 RS
Engine: 5.7 TPI / L03 TBI
Transmission: 700r-4 / 700r-4
Axle/Gears: 9 bolt 2.77 posi / 10 bolt 2.73
The lock plate tool does help. I would use two small screwdrivers to work the snap ring off.
Old Sep 1, 2007 | 08:53 AM
i have the lock plate remover too it is just that the snap ring is the hard part i play with that thing for what seems like an eternity. really like 25-45 mins depending on how frusterated i get. the madder you are the longer it takes.
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
TrevinE
Sep 14, 2015 03:20 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
