HVAC problem
Old Sep 14, 2007 | 01:03 AM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
HVAC problem
all4u's post and the cooler weather has reminded me that my heater doesn't exactly work anymore. whenever i turn on the heat, air, defrost, etc it likes to make a loud shrieking noise similar to that of a loose belt or a party kazoo. It started probably over 6 months ago and would only do it for a second or so but it got progressively worse over time to the point that as soon as I turn on the air it makes the noise, no matter what speed or setting. When it makes the noise the heat/air stops blowing rendering my heater useless. It is very loud and you can hear it from both outside and inside the car in the area of the heater box. I should probably add that I have removed the A/C pump and hoses but still have the stock heater box. I know nothing about the HVAC system so any help would be much appreciated.
Old Sep 14, 2007 | 05:10 AM
archemedes's Avatar
Car: 1997 Grand Prix GTP (for now)
Engine: 3.8 sc
Re: HVAC problem
I am guessing blower motor
Old Sep 14, 2007 | 05:24 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: HVAC problem
JamesC
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
Glowsock
Sep 6, 2015 06:40 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
