HELP!!! HATCH WONT LATCH 88 IROC
Old Nov 9, 2007 | 08:24 PM
GEOFF1983Z28's Avatar
ANYONE KNOW HOW I CAN GET MY HATCH LATCHED...THE POWER PULL DOWN MOTOR WENT BAD AND I GET MY HATCH TO STAY CLOSED.EVERY TIME I CLOSE A DOOR IT GOES UP ! i NEED A TIP ON GETTING IT CLOSED UNTIL I GET A NEW MOTER. I DONT WANT TO KEEP SLAMMING IT HOPING IT WILL CATCH.THE LATCH IS TOO LOW
PLEASE HELP !
PM ME OR POST ANY IDEAS
GEOFF
Old Nov 10, 2007 | 10:12 PM
Staten Island S's Avatar
Car: Camaro, Monte,
Re: HELP!!! HATCH WONT LATCH 88 IROC
That has happened to me many times in my 11 years of owning my 3rd gen camaro- its a quirky thing with these hatches. Believe it or not if you give it a good slam- it will catch. The thing is that sometimes the electric motor doesn't engage correctly when lifting the hatch- especially if your hatch struts are shot.
Old Nov 10, 2007 | 10:54 PM
GTA50's Avatar
Car: '88 GTA, '89, '94 Firebird, '84 T/A
Engine: 5.0L TPI (GTA); '89 -2.8; '94 -3.4
Transmission: 5 speed (for all 3),auto for T/A
Axle/Gears: 3.45 (GTA only)
The other option is to remove the back plastic cover, then remove the motor from the hatch mechanism. Insert a small screwdriver into the opening created by removing the hatch motor and turn the gear wheel to raise the "catch" for the "hook" for the hatch lid. Raise it until the "catch" is high enough to engage. Your back deck will sit a little higher but it will catch and lock.
Gary.
Old Nov 12, 2007 | 12:19 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Before you start slamming the latch, read the answer I posted in your other thread in the "Body" section.
Oh, what the heck. Go ahead and slam it. I could use the business. lol
Lon Salgren
Top-Down Solutions
Old Nov 12, 2007 | 12:49 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
when mine broke I used 3 pairs of vice crips to hold it down it worked good, while I waited for my repair kit from TDS to come in I would suggest getting it best money Ive spent in a long time I dont think ill ever have to worry about repairing it again
Old Nov 12, 2007 | 09:18 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Lon Salgren
Top-Down Solutions
Spoken like a true prophet, I close my hatch with the gentle touch only a mother knows and she is still working like new after 19 years I also make sure the contact plate is kept clean, the motor stays clean, and the hatch struts work, and ounce of prevention is what I heard
Old Nov 12, 2007 | 10:26 PM
lonsal's Avatar
I'll share a bit of information. The contact plate has nothing whatsoever to do with the pull-down unit. It powers the rear wiper on early F-bodies and the HMSL (high-mount stop light) on the later cars. When the HMSL moved to the top of the rear hatch in model year 1991 it dissapeared.
Lon
Old Nov 18, 2007 | 03:05 PM
230 firebird's Avatar
Car: 1987 pontiac firebird
Engine: sbc 350
Transmission: TKO 600 5 speed
Axle/Gears: 323 posi/disc from 86 gta
I agree with gta50.You need to remve the motor,then raise the unit up a little.You might only need a new reversing relay,instead of new hatch motor.John
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
Poncho92
Group Purchases
Aug 25, 2015 02:17 PM
Randomtask2
Aug 13, 2015 01:57 AM
mustangman65_79
Aug 11, 2015 03:17 PM
z28addict8490
Aug 7, 2015 08:48 PM
