Speedometer
Old Dec 24, 2007 | 12:18 AM
CamaroRS-91's Avatar
Speedometer
my speedometer doesn't work what should i do also my back lights wont work any suggestions
Old Dec 24, 2007 | 01:29 AM
82lg4camaro's Avatar
Re: Speedometer
not so sure for the 91 model but for my 82 camaro i would checked the fuses on the fuse box one little fuse can make a lot of things work
Old Dec 24, 2007 | 06:44 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Speedometer
Welcome to TGO. CamaroRS your speedo is electronic. You might check the VSS--and certainly do a search as your problem is common. 82lg4, yours is mechanical so a fuse won't do the trick.
JamesC
Old Jan 7, 2008 | 06:17 PM
mike_4_49ers's Avatar
Re: Speedometer
I had a 91RS, speedo quit working. turned out to be the speed sensor. not an expensive part and it's attached to the tranny in a easy enough place to get to.
Old Jan 7, 2008 | 06:39 PM
rally24's Avatar
Re: Speedometer
I have the same problem. Except for a while it would sporatically just start working. The question I have is I look up speed sensor and two thing show up a sensor that goes in the tranny and one that bolts on like a connector. My brother and I changed the sensor in the tranny. It stopped working at all. I have a 1991 Camaro RS 5.0 305 tbi. Any Ideas
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
