I just posted this on my local f-body forum (newyorkfbody.com), and figured I would post it here also.. I might've posted some of this here before but I don't remember how well I wrote it up, so here goes!
I started with a t-top headliner from a junkyard car that was in exceptionally good condition (considering the age).
I removed the old headliner material and thoroughly removed the foam backing using a nylon bristle brush. For any areas that were starting to tear, I soaked it with headliner adhesive. Resin would probably work well too.
I wanted to make it smoother than stock by shaving the dome light. I installed a rear view mirror with map lights so the dome light won't be missed.
I cut a piece of cardboard to exactly match the hole. I then cut another piece slightly larger. I used the headliner adhesive to adhere them together. The function of the larger piece (not pictured) is to give a good surface area to adhere to the headliner board. I used a skim coat of good old bondo to smooth over the cardboard since any imperfection will show through the headliner material. I used a palm sander after the bondo set.
I also decided to shave the slit for the rear seatbelts and only keep the hole for the belt to come through. The slit was initially needed because of the 3rd gen lower retractor, but I don't need it any more because I swapped to 4th gen seatbelts without the lower retractor.
The headliner material can be purchased from most fabric stores. It's a felt fabric with a 1/8" foam backing. (Headliner material also works well as a poker table cloth... but that's another project). I had to special order mine due to the color not being stocked normally (it's charcoal). I believe 2 yards is more than enough but I bought more to use on the rear speaker covers and the door panel inserts.
Permatex Heavy Duty Headliner and Carpet Adhesive is the brand I used and hightly recommend. To conform to the curves of the t-top headliner, I had to adhere one small section at a time. The permatex bonds immediately and won't peel away when pulling tight for the next section. It really takes a lot of patience to get it without wrinkles.
Problems not yet solved:
The dome light also helps hold the headliner in place. I tried using adhesive backed velcro in it's place, but it separated from the headliner board easily. I might recommend sewing the velcro to the headliner prior to smoothing with bondo or just finding a better adhesive. It hasn't sagged much so far due to the mount not being there, but I wouldn't want it to experience the added stress over a long period of time.
looks good
Excellent job
When I repair headliners I glue a straitened stiff clothes hanger to the backside with hot glue. I never removed the dome light but this may help your sagging problem
It looks awsome, nice work.
Nice job, looks great
whadda messy garage.....i may have asked..but did you know/whaddya do when the headliner is cracked like my old one? i'd just call and ask, but you're busy playing w/your car at the track and ill ferget.
for minor tears/fraying I just used some of the headliner adhesive to hold the fiberboard together. If it's more serious, I'm thinking resin would work very well for repairs. I'll have to tell you my track story later on.
Quote:
i got a Q about the 4th gen seat belts how would i go about doing that to my gtaOriginally Posted by JeremyNYR
for minor tears/fraying I just used some of the headliner adhesive to hold the fiberboard together. If it's more serious, I'm thinking resin would work very well for repairs. I'll have to tell you my track story later on. The front belts are pretty straight forward. The top retractors mount just as the 3rd gen ones do. On the bottom, remove your old retractor and remove the 90 degree bracket that the old retractor mounted to (it's held in with 2 bolts going into the body. one is identical to the large bolt that mounts the retractor and the other is a small 10mm bolt). I ended up removing the plastic sheathing from the bottom of my 4th gen belts, but that isn't required. Then just bolt the metal loop on the bottom of the 4th gen belts into the body in place of the old bracket that you removed.
the rears are a little more difficult, because the reatractor assembly is taller for the 4th gen rears than it is for the 3rd gen units.
im not to worried about the back no one hardly sits back there since there isnt really any room but thanks alot for the help im in the process of doing my interior i pulled about just about everything im in search of new seats and carpet and all the interior plastic peices i took out and i thought id do something a lil diffrent and upholster all the peices in a black carpet lookin stuff ill post some pics upOriginally Posted by JeremyNYR
The front belts are pretty straight forward. The top retractors mount just as the 3rd gen ones do. On the bottom, remove your old retractor and remove the 90 degree bracket that the old retractor mounted to (it's held in with 2 bolts going into the body. one is identical to the large bolt that mounts the retractor and the other is a small 10mm bolt). I ended up removing the plastic sheathing from the bottom of my 4th gen belts, but that isn't required. Then just bolt the metal loop on the bottom of the 4th gen belts into the body in place of the old bracket that you removed.the rears are a little more difficult, because the reatractor assembly is taller for the 4th gen rears than it is for the 3rd gen units.
