Went to the junkyard the last 2 days. Didnt do too bad *pics*
Old Feb 10, 2008 | 07:47 PM
BigBadJohn's Avatar
Got basically a complete set of trunk plastics, some fan switches, door lock switches, interior screws, door pulls, alternator bracket, and a cluster set for my pickup
Spent $114 the last 2 days there
Also. Found a good upper seat and a good lower seat in separate cars. I was wondering if I could put the padded parts only on my drivers frame
Old Feb 10, 2008 | 07:48 PM
BigBadJohn's Avatar
Re: Went to the junkyard the last 2 days. Didnt do too bad *pics*
Old Feb 10, 2008 | 07:55 PM
Stippy17's Avatar
Car: 1986 Trans Am, 1985 Trans Am
Engine: 400 SBC, H.O. 305
Transmission: TH400, 700R4
Axle/Gears: 10 Bolt/3.73s, 10 Bolt/3.73s
Nice finds. Are the upper and lower pieces from driver's seats?
Old Feb 10, 2008 | 07:57 PM
BigBadJohn's Avatar
No passenger seats. I didnt know if I could get away with using only the padded parts and then just use all the driver frame and hardware
Old Feb 10, 2008 | 08:04 PM
Stippy17's Avatar
I could be wrong, but the holes are different such as the seatbelt guide holes. I used lower and upper pieces from different cars to make a better seat but they were both from driver's seats and I used them to replace my driver's seat.
Don't just listen to me though, let a few others reply to confirm or diagree with what I've said.
Old Feb 10, 2008 | 08:19 PM
BigBadJohn's Avatar
Well I could prolly reuse the head piece. I think it should just lift right out
Old Feb 11, 2008 | 01:03 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Nice...I need that alternator bracket...good find ...I will be looking for one ofthose this spring...Where's New Athen's...I am near Chicago but if they have more Camaro's you never know...
Old Feb 11, 2008 | 05:06 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
pretty good find, here is a link about seat covers and such.
https://www.thirdgen.org/forums/inte...ver-seats.html
Also the head rest doesn't just pull out when you have the cover off there is a metal tab that has to be turned.
Old Feb 11, 2008 | 07:22 AM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
73-87 Chevy/GMC P-Up?
I just ask cause if you need any other parts for the truck i know a guy who lives here in Il who restores those trucks. and has piles of parts
Old Feb 11, 2008 | 09:16 AM
BigBadJohn's Avatar
Theres one more car with the same bracket, NiteRider, if I can manage to get it off. The one bolt's head is stripped though.
Im like a 4 hour drive from chicago, the junkyard is near st louis
Old Feb 11, 2008 | 09:31 AM
BigBadJohn's Avatar
Apparently its a somehwat simple swap. All I need to do is get the driver frame and upper foam, the passenger cover, and a passenger bottom and I should be good to go
Old Feb 11, 2008 | 09:38 AM
Stephen's Avatar
Car: 87 GTA
If you switch the foams, your seatbelt guide will be on the wrong side, and what about the tilt forward lever? Wrong side again. Slider mechanism? It may attach to the frame, not the cushion itself, so you may be good there.
Old Feb 12, 2008 | 09:34 AM
BigBadJohn's Avatar
So I can take both covers off easily and except for a few holes I may need to sew up or cut open, the covers themselves should fit a drivers frame and foam?
Old Feb 12, 2008 | 09:41 AM
Stephen's Avatar
Car: 87 GTA
I'd SUSPECT you could, but I've never torn one apart to KNOW, yes or no. But the look possible.
If it doesn't work, don't go...."Stephen said I could! DAMN HIM!"
Old Feb 12, 2008 | 10:02 AM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Why the stock radios?
Old Feb 12, 2008 | 10:38 AM
BigBadJohn's Avatar
I plan on figuring out how to wire in an auxiliary input and making a custom ipod dock for my car
Old Feb 12, 2008 | 11:39 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Yes, when I had mine re-done I used the fabric, foam and the basket from the donor passenger seat, and on the side where there are holes from when the back mounts to the bottom the whole sides were replaced by the old drivers seat sides.
Also not really "easy" the hog rings are kind of a pain to work with. I just took my donor seat and my old seat to an upholstery shop and they did it all for $130.
Old Feb 12, 2008 | 07:20 PM
BigBadJohn's Avatar
Didnt have anything that could cut through those damn hog rings
Old Feb 13, 2008 | 01:55 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
You don't need to cut through them just take some pliers or channel locks and bend them to open
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
L98GTA87
Oct 19, 2015 10:43 PM
dimented24x7
Sep 17, 2015 06:58 AM
gta892000
Sep 16, 2015 12:40 AM
