Hatch Motor expired I think
Old Feb 23, 2008 | 12:56 PM
87IROCZCamro's Avatar
Car: Chevrolet Camaro IROC-Z,96 Vette
Engine: 350 5.7 Liter
Transmission: 700r
I started my car today pulled it out and started to clean it. I opened the hatch and then when I went to shut it. it wont lock in or pull down. Any suggestions. i have some pics up
Old Feb 23, 2008 | 01:04 PM
Transmission: 700r
Re: Hatch Motor expired I think
Old Feb 23, 2008 | 01:16 PM
Transmission: 700r
I just went outside to look at it and I got a screw driver and push down on the connector thing ( I dont know what you call it) and It does lock. I my pull down lock ( the hook part) I think is not rapping around to pull it down.
Old Feb 24, 2008 | 04:09 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
First you can try pressing on the striker sensing switch. That is a small switch that is pressed by the hatch hook to start the pull-down units down cycle. It is located just in front of the latch and is held onto the latch assy by a small hex-head screw. There are four wires coming out of the switch. If pessing the switch does nothing, then remove the hatch surround trim panel. Two Phillips screws, one on each side of the hole that the latch of the pull-dow latch protrudes through and four large plastic screws to remove to get the panel out. Unplug the red/white stripe wire from the blue wire and test it for 12v. If you get no voltage at that wire check for a blown fuse. It might help you to dowload the Tech Article on repairing these pull-doen motors I wrote that is posted on Thirdgen.org.
Just to let you know, the contact pad you posted a picture of has absolutely nothing to do with the hatch pull-down unit. It powers the HMSL (aka third brake light).
Lon Salgren
Top-Down Solutions
Old Feb 24, 2008 | 05:42 PM
Transmission: 700r
Lon Salgren
Top-Down Solutions
sweet thanks, Just to let you know the hatch button does work and does release if pressed. I have no idea what the problem could be
Old Feb 24, 2008 | 11:30 PM
lonsal's Avatar
The hatch release solenoid is powered on a different circuit than the pull-down motor.
Lon
Old Feb 27, 2008 | 06:00 PM
guitargod2138's Avatar
Car: 1992 Camaro RS
Engine: 305tbi, some bolt ons
Axle/Gears: 3.73 posi
the same exact thing happened to my 92 RS, except my dumbass pushed it down too hard and i broke something in the motor, so i went in and moved everything out of the way of the lock and it closes fine, i just cant open it via the switch, only manually. those motoros are very hard to come by, so dont do anything to break it!
Old Feb 27, 2008 | 06:31 PM
Transmission: 700r
Well my dumbass friend did try to push it down and I said "It will do it by it self!" but he kept trying
italiano67
Dec 11, 2016 09:21 AM
zayne0
Aug 24, 2015 07:22 PM
neekolzun
Aug 24, 2015 04:59 PM
madsv1000
Aug 20, 2015 06:45 AM
stalkier
Aug 13, 2015 12:59 PM
