Gauges
Old Mar 9, 2008 | 12:31 AM
all4u's Avatar
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
Gauges
What three gauges do you think would be the most important to have in the car? I was thinking oil and trans temp and maybe a vacuum gauge. Triple gauge pod is on the way. I would like to have auto meter gauges only. Suggestions and install info is what I'm after, and as always, thanks ahead of time.
Old Mar 9, 2008 | 04:05 AM
jaron's Avatar
Car: 1982 Pontiac Trans Am
Engine: 305 V8
Transmission: TH200
Re: Gauges
well im thinkin the fuel gauge might be pretty important!
Old Mar 9, 2008 | 09:31 AM
all4u's Avatar
Car: Firechicken
Re: Gauges
I was thinking fuel pressure, but does anyone have a serious reply? What are you guys using in your cars for gauges? I noticed that some people hide the nitrous pressure gauges in their cars so this summer when I start spraying, I will try to hide the gauges where the ash tray is. I'm getting the pod for the cost of shipping so I don't know what I should put in there. Any ideas?
Old Mar 9, 2008 | 11:18 AM
87IROCZCamro's Avatar
Car: Chevrolet Camaro IROC-Z,96 Vette
Engine: 350 5.7 Liter
Transmission: 700r
Re: Gauges
Old Mar 9, 2008 | 12:45 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
Re: Gauges
well everything that is there stock plus trans temp, fuel psi, and boost (if you have it) that's all i think you would need.
Old Mar 9, 2008 | 01:54 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Gauges
if you are just looking for gauges to monitor critical engine temps/pressures
oil pressure, water temp are a must, gas is important, a vacuum gauge is not worth a damn unless you are using forced induction, a wide-band o2 would be useful.
Old Mar 9, 2008 | 06:17 PM
jcisthechamp05's Avatar
Car: 1987 IROC-Z
Re: Gauges
I agree, oil pressure and water temp are probably your most critical. Then if you want to pull apart the fuel rail, fuel pressure woudl be pretty nice to have (should you not ever start). Then when you get to tuning, as suggested wideband, a/f ratio.
Edit, If you're looking for easiest set up: volt, vacuum, temp
Old Mar 9, 2008 | 06:30 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: Gauges
[quote=
Edit, If you're looking for easiest set up: volt, vacuum, temp[/quote]
a clock is pretty easy too
Old Mar 9, 2008 | 06:52 PM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
Re: Gauges
not meaning to hijack but has anyone ever put a shift light in one? i think that would be pretty neat.
Old Mar 9, 2008 | 08:29 PM
Car: 1987 IROC-Z
Re: Gauges
Haha, lol yah it is.
Old Mar 9, 2008 | 08:37 PM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
Re: Gauges
are you lookin to monitor your status or tune?
monitor status: oil pressure, oil temp, water temp
tune: wideband o2, fuel pressure, and an accurate tach (stock tach is about as accurate as a politician)
Old Mar 9, 2008 | 09:43 PM
all4u's Avatar
Car: Firechicken
Re: Gauges
I have a 89 formy 350 auto so from the factory I have the coolant temp, and oil pressure. I would like an oil temp and fuel pressure. How hard would it be to wire and should I get electric or mechanical gauges? Thanks ahead of time for the input.
Old Mar 9, 2008 | 11:01 PM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
Re: Gauges
stock temp and pressure guages are more accurate than the tach, but still not very precise.
neither oil temp or fuel pressure is really that difficult, just possibly time consuming. I would use electric, but thats me.
for oil, ive seen somewhere an adapter that fits between your filter and the filter adapter on the block, kind of like an oil cooler adapter, that was set up to have guage senders attached. saves the trouble of tapping a hole in the oil pan to fit the sender.
Old Mar 9, 2008 | 11:34 PM
all4u's Avatar
Car: Firechicken
Re: Gauges
Great! Where do I get this adapter and what is the part number. I wanted to get all autometer gauges but if your adapter only works for certain gauges, I could be open minded.
Old Mar 10, 2008 | 08:26 AM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
Re: Gauges
i dont remember where I saw it..since i randomly look through catalogues and parts sites all the time....do a search online or check through the usual sources.
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
