145 speedo is off
Old Mar 15, 2008 | 05:48 PM
mbolte's Avatar
Car: 1987 Camaro
Engine: 350 dart ies comp cam intake carb
Transmission: 700 r4, shift kit, 2400 stall
Axle/Gears: 10 bolt stock
145 speedo is off
hey all,
well my car had a 85 mph speedo in it, and it was off pretty bad because i went 2.73 to 3.73 for gears...well i changed to a 145 speedo and its off also which i know is right because of the gears...but now its off probably about 70 mph! going down the highway it says 145...my question is did the guy that i bought the speedo from just bolt a 145 plate to a 85 set of gears?? Or is it possible that the speedo is actually that far off?
thanks for any help guys!
Old Mar 15, 2008 | 07:03 PM
Titan85's Avatar
Car: 1987 Camaro SC
Engine: 305 LB9
Axle/Gears: 3:42
Re: 145 speedo is off
I don't really see anything that could cause that kind of malfunction unless it is an electronic speedo. The only thing that should be causing the speedo to be off is the driven gear on the transmission. It needs to be changed to the one with the correct teeth for the new gears.
Other than that, I would say check the speedometer cable for any problems. I suppose that the speedo could be broken, but I have never seen one go before so I wouldn't bet on that being the problem.
Old Mar 15, 2008 | 07:20 PM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
+1
Your speedo is off due to the gear change, you can change speedos as often as you want, but until the drive/driven gear combo in the transmission tailshaft is corrected it will be off.
do a for speedo gear changes..there are several threads regarding this and I believe a tech article or 2. The correct gears are available from many aftermarket trans vendors.
Old Mar 15, 2008 | 08:15 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Change gearing and, unless you swap out the drive and/or driven gears, the speedo will be off regardless of the speedo head: 85, 110, or 140. Check the following site:
http://www.transmissioncenter.net/sp...n_______va.htm
JamesC
Old Mar 15, 2008 | 08:59 PM
mbolte's Avatar
Car: 1987 Camaro
alright thanks guys!!! i just wanted to make sure that the guy i bought it from didnt mess with me
Old Mar 17, 2008 | 07:41 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Best way to calibrate the speedo is bring it into a shop where they can set it up on a bench and make the adjustments.
My "electronic" speedo and tach are adjusted by gently removing and repositioning the needles by hand.
Old Mar 17, 2008 | 08:19 PM
JamesC's Avatar
Under normal circumstance, there is no need to calibrate the speedo head after a swap.
JamesC
Old Mar 18, 2008 | 08:26 PM
Pukka's Avatar
JamesC
The trick is not to touch the needles while handling the cluster. On the 90-92 models its much easier to maneuver the cluster with the clear cover off - so avoiding the needles requires constant attention.
Old Mar 18, 2008 | 10:32 PM
mbolte's Avatar
Car: 1987 Camaro
well right now my speedo sits at like 8 mph without the car moving?
GTAman
Jul 3, 2024 07:29 PM
Elephantismo
Feb 13, 2019 12:51 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Kylej68
Exterior Parts Wanted
Sep 28, 2015 10:00 AM
TrevinE
Sep 14, 2015 03:20 PM
