Replacing a Powered Rear view mirror but
Car: Different Rides but 1991 Firebird
Engine: V6 3.1 in Bird
Yesterday I went to the junk yard like I always do on Wednesdays due to being half price days. Well I found a very nice shape Rear view mirror with the map lights. Now my rearview mirrow works great with the maps lights also accept the mirror has a bunch of scrapes or something like the mirror part is coming off in diff spots. Now the new one has a 3 wire setup and mine has a 4 wire setup. Does anyone know what wires are what so I can just hard wire it or is there a way to remove the mirror part only and install it into mine without breaking stuff. Thanks
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: Replacing a Powered Rear view mirror but
The 4 way wiring probably includes the wire for the third brake light.
Your car has four wires to the powered mirror and 3rd brake correct? If so, it includes wiring connected to the brake switch as well as the mirror. BTW, the mirror is powered from your acc fuse.
OK then does anyone have a diagram so I can rewire the harness or again is there a way to remove the Mirror itself and then install it into my rear view mirror.
Try a search on the ACC fuse and review several old posts. You'll find at least one or more links to schematics there.
Good luck
Good luck
Well being that I take stuff apart at work to fix it I decided to try to open the mirror. Well I used a plastic pick with a flat head end and put it in between the trim piece that holds the mirror in place. It camp apart very easily and then pulled the mirror itself out and that was that. Did the same with mine and put them back together and it works PERFECT.
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
That's what I was going to tell you to do. I did the same with mine.
1992 Trans Am
May 10, 2023 07:19 PM
