How to remove steeringwheel ?
Car: 1989 IROC-Z
Transmission: Th700R4
Couldnt change the ignition lock cylinder yesterday,
have to order an Steering wheel disambly tool... for $12.. i think
Is there any other tool I need ?(or could I just jiggle the steeringwheel and take it off without any special tool?)
in the haynes manual it says I need an lock plate depressor tool do I really need that one if I shall change the ignition lock cylinder?
because I dont think I can get it in Sweden...
And the car has to be ready in about ~10days..
Will I do fine with only the puller tool (Steering wheel disambly tool).
Please help me out.
Please help me out.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Car: 1989 IROC-Z
Re: How to remove steeringwheel ?
I dont know how much I need to remove to change the ignition lock cylinder.. anyone now if I need another tool for that ?
Thanks for your response JamesC
Maybe something in the following link will be helpful:
https://www.thirdgen.org/forums/tech...ced-there.html
JamesC
JamesC
Car: 1989 IROC-Z
Thanks, seems like I need to buy that lock plate tool afterall...
Well that may be a problem over here in sweden..
Car: 84 Z28
Engine: carb 305
Get the puller and you MUST have a security plate tool, you can rip it off with your hands but its impossible to put back on without the tool unless your a he man. both tools cost around $50 together and also make sure you take out every screw before you try to pull things I broke my signal lever internals once becuase i thought it was jsut being stubborn but there is some pretty well hidden screws in there.
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
This web page will walk you through, right down to fixing the tilt screws. It's from a Fiero site, but identical in every way.
http://www.fieros.de/en/articles/steering.html
Car: 91 RS Vert/98 Sierra9
Engine: 5.7/5.0
Transmission: 5spd/auto
Axle/Gears: 4th gen rear with 3.73
i changed my lock cylender recently and all i needed was a steering wheel puller. Took me some time but i got it done lol i don't know what that security plate tool is but i didn't use one. Not sure if it matters but it was on an 85 5spd z28
Car: 1989 IROC-Z
I need to get to the VATS connector to.. Really dont know where that sits but I will see after I removed the steeringwheel.. Does anyone know how far down the steeringcolumn the VATS connector is connected ? Do I reach it without disambling the whole column ?
Car: 89 Iroc Convertible
As far as I know you only would use a lock plate compressor tool if you have a tilt column.I needed one to change my turn signal switch when it broke
Was it a tilt wheel? It matters on a tilt, don't know on a non-tilt. On a tilt it keeps the the upper shaft centered and secure.
Engine: 5.7/5.0
me why? i put it back in just how it was and it had been working fine. I've been driving the car around for months. You probably have me confused i wasn't asking for help i just mentioned i swapped out my ignition switch without using that security plate tool. Well I parted out the car already and have that column sitting in my garage as a spare
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
*Flex's*
I must be a HE MAN.
Heh, just playin. Its possible to put back on with 2 people but its EXTREAMLY aggrivating trying to get it right and it kills your hands trying to push down on the plate that hard. Not to mention its probably not good for the seat, what with the back pressure your putting on it and all.
BUT, none the less, it can be done if you have 2 competent people with more than your adverage housewife's strength in em.
I must be a HE MAN.
Engine: 5.7/5.0
ahhh ok i get it now well its off the car and not in use since i picked up a vert. So I will compare it to that one. Thanx for the heads up
Car: 89 RS Convertible
Engine: 305 tbi
Transmission: 700R4,B&M friction,Transgo shiftkit
Axle/Gears: 2.73 LSD
you will need to pull the plastic trim under the column... the big piece that the fuze box cover attaches to. the VATS wire snakes through the column and there is a connector underneath. to make installation of the new VATS wire easier you can cut the old wire at the cylinder and then tie or tape it securely to the connector end of the new cylinder's wire and use it to pull the new wire down through the column. then just plug it in. remember to save the resistor from the old key so it can be uset to set the new key's resistance value.
I had always thought that there was a plastic cover down there, when I bought my car it seemed not to come with one.
If anyone has a spare they would be willing to part with, PM me and let me know a price.
Josh
Josh
Car: 1989 IROC-Z
Thanks for all the answers.
Will see if I can get the lockplate depresser tool anywhere..
The keys is already made
but thanks for the reminder of it
Will get back here with some info about how its going to end..
Thanks again.
Thanks again.
