What color SEM dye for the light grey....
Car: 1971 Camaro
color are you guys using on your side/ rear plastic trim ?? It's the lighter gray that was popular on a ton of 82-92 camaro and firebirds. It looks like sems "warm grey" but I wanted to be sure before I bought a can.
What have you guys used and got a pretty good match to stock?
Car: 1971 Camaro
Re: What color SEM dye for the light grey....
Man it's hard to get posts answered around here.....nothing moves much....now off my soapbox.
Let me ask a different question about the same subject.....has anyone had custom dye mixed at a shop for the darker grey..such as a 85-92 firebird console.
I thought it would be sems graphite, but it's too light...so another alternative would be to get a shop mix the dye. Anyone done this yet?
Car: 91 Camaro RS 92 Camaro RS
Engine: 406, 305
Transmission: TH350, 700R4
I'm not sure if this will help but when I dyed my interior I went to the local paint shop and had them look up the color for me. They have books (just like color RPO for exterior paint) for the interior of all years of cars. Have a paint shop look it up, and try that. From experience for best results buying something like duponts line or even martin senior from napa and spraying it out of a gun works great. Good luck to you!
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
the computer is the second WORST possible place to try and color match, first being a dark room. Warm grey looks great on my screen. but that could be way off due to my computers settings.
Car: 90 RS
Axle/Gears: 2.77
If you are concerned about it matching you might want to consider painting all of the grey panels one color.
Car: 1992 Firebird Formula 350
Engine: 5.7 TPI
Axle/Gears: 3.23 Posi
Did you ever get an answer? I'm trying to figure out which paint is right for that gray too.
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
the only real way to figure it out other than taking it to the pros is trying some and getting lucky unless someone has already tried got lucky and remembered what he used.
I used SEM Landue black on my 1995 firebird dash before swapping it into my 87 camaro.
love the results
love the results
LT1Formula
Aug 20, 2015 09:36 PM
