Does Anybody Else Have This "Option?"
Car: 84 T/A
Engine: 400
Transmission: Turbo 350
Took a look at the IROC today to see what 4th gen parts I was going to install first and I found this "option." The back of the car is black carpeted from the sail panels back. Also, I have the Bose stereo and there are 2 8" subwoofers in the rear as well. I'll put up a pic later today. Is this part of a special package, or did a lot of people get this "option?"
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Re: Does Anybody Else Have This "Option?"
If the entire panel is carpeted, leaving no plastic showing at all, then it is non-factory. My 86 IROC has the same carpeting. The factory amplified sub option goes in the place of the rear "Glovebox" on the drivers side, left. Kinda rare in 87. Its worth money if you take it out and dont want it.
Car: 84 T/A
Engine: 400
Car: 1987 Z28 with iroc-z Package no.3
Engine: 350TPI
Axle/Gears: 3.73 posi
this WAS factory option. i believe it was called LUGGAGE TRIM ill have to look up that option code.
Car: 84 T/A
Engine: 400
I thought it was kinda weird/rare, because I've never seen the carpet back or 2 subs in the rear hatch area. Do you think it would be possible to take the little subs out, cut bigger holes and put 2 12's or 15's?
Car: 89 Iroc Convertible
If you have the bose option then you should also have the bose kick panels up front.I have the bose hard hatch cover and a pair of kick panels in my basement that were pulled from a 1987 LT Camaro.The carpeting on the rear plastics was the deluxe interior
Car: 84 T/A
Engine: 400
By kick panels do you mean by the pedals? Do you have any pics?
Your kick panels should be thick and not flat like regular kick panels
I would love to have those kick panels!!!!!!!!!!!!!!!!!!!!!!!!!! That is bad-a**!
I want some!! I have not seen those before. The rear one I've seen. Some restorer will want the rear well panel, I wouldnt cut it up. Besides, its plastic, if you cut it and drop 1 or 2 heavy subs in it then it will crack. Build a board out of 1/2" mdf and use the cover as a template, then cover it with black carpet. It will last,sound better and look better too!
Car: 1992 Rs
Engine: 305 TBI
Transmission: 5-Speed
Axle/Gears: 3.08
Heh My 1992 Rs Camaro also has these.. Big front kick panels and rear hatch bose subs. It IS a factory option and it is called UQ4 SPEAKER SYSTEM 4, BASE
Thats the Rpo From my car that I think it is. check if your car has that.
And Since I know some one will ask, I edited the vin out of there for safty reasons.
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
This is not true.My 86 had the carpeting all the way back and it came from the factory this way.I was the only owner and it had been sitting at the dealership just a few days when I bought it
Car: 1992 Rs
Engine: 305 TBI
Axle/Gears: 3.08
another thing that makes my other car weird is that My rear sail panels have carpet on them to. in my 86 iroc-z. just no bose speakers.
those are the only pictures I have of it
Car: 84 T/A
Engine: 400
Thanks for all the info guys!! As to how it sounds, I don't know lol. The motor's still not in it and the guy I bought it from said it only works sometimes when you mess with the radio. I'm guessing a ground wire. Regardless, I'm most likely pulling everything Bose out of the car because I'm changing the headunit.
Yeah my 90 Iroc has the bose stereo option. I installed two kicker 6.5" subs in there powered by an alpine amp and it sounds very nice. I like the fact that everything looks stock and i get some very nice base out of it.
Those rear speakers are not subs. The Bose system is a 4 speaker system and those are the rear speakers. The bose system has an amplifier at each speaker. By removing those and adding just subs, you only have a left and right from the front and bass from the rear.
Also, the carpet is factory as part of the deluxe interior package.
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
my 88 had the option, i stripped it all out and sold the pieces.
i got 165 out of the kick panels, and almost 200 bucks for the rear amps and speakers.
i kept the cover itself to hide my nitrous bottle and make for a more clean interior.
my buddy at GM said that the rear bose cover with amps and speakers is still available for 1300 bucks. LMAO.
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
I have that in my 87 LT. Red carpet all over and the Bose System. I did manage to hook up 6x9 speakers in the sail panels to the rear Bose and then the upper dash speakers to the lower front kick panel speaker. Very nice and loud.
Car: 88 Camaro
Engine: L98 350
My 89 had the same deal, all carpet with the Bose option, rear area light. Good sounding system but with all the road noise in the car it was lost on some highways. Really amazes me how Bose gets so much sound out of the small speakers they use in most of their stuff.
Car: 1983 Camaro Z28
Engine: 305, holley 4bbl. stock for now
Transmission: th200c, 700r4 coming in spring
my 83 has carpet all the way to the back, and actual speaker grille cloth on the sails.
hmmm, the guy i bought it from, DID say it was a custom order from someone that worked for GM.
i even have a 165mph speedo
no bose though
no bose though
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Carpeted rear panels was known as the "deluxe interior." Your kickpanels should also be carpeted.
Will
Will
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: A/T
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
sold off the stuff and basically bought a system for free.
looking back on it, i wish i would have held onto all that stuff.
10 years ago i didnt know much about it, and really didnt care then.
could be worth a lot more in the years to come.
gixxer92
May 18, 2017 11:20 AM
