speedometer/odemeter doesn't work
Old Sep 13, 2008 | 04:37 PM
19transam86's Avatar
Car: 86 trans am
Engine: 5.0 305
Transmission: 5 speed
hi guys, i bought an 86 firebird without the speedo working, do you guys know what to check or how to check the cable or gears related to the cable
thanks, MAtt
Old Sep 13, 2008 | 05:46 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: speedometer/odemeter doesn't work
Sorry, I can't recall off the top of my head. It may well be that your 86 is electronic, not cable driven. A search should provide the info you need.
JamesC
Old Sep 13, 2008 | 08:55 PM
Car: 86 trans am
Engine: 5.0 305
behind the gauge cluster is a little plug in but you can follow the cable to the tranny but the only way to see it is to take it apart and i want that to be a last resort
Old Sep 13, 2008 | 08:59 PM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
But start at the tranny first and work up. Usually people unhook them to keep the documented mileage off of the odometer. At the transmission is where they usually do it. By the way, how many miles on the car?
Old Sep 14, 2008 | 08:09 AM
Car: 86 trans am
Engine: 5.0 305
111495, but that has been the mileage since at least 2004
Old Sep 14, 2008 | 09:35 AM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
86 shouldn't have a cable speedo. And if for some reason your speedo is pegged at top speed it wont work unless you pull it out and shake the needle so it sits at zero again.
Old Sep 15, 2008 | 10:20 AM
Car: 86 trans am
Engine: 5.0 305
yeah it doesn't have a cable, its electric
Old Sep 18, 2008 | 06:15 PM
brians88gta's Avatar
Car: 88 gta
Engine: 350 HSR
Axle/Gears: 3:27 borg warner 9 bolt
there is a sensor in the tranny as well as a signal converter in the dash should be a little yellow box auto zone carries both 4 69 dollars apiece
Old Sep 19, 2008 | 06:13 PM
Car: 86 trans am
Engine: 5.0 305
is there a way to tell the sensors are good or not. $140 is alot to spend if i don't need to
Old Sep 24, 2008 | 08:20 PM
Car: 88 gta
Engine: 350 HSR
personaly i dont know how to check them but i would say the sensor in the tranny im doing a trial and error on my speedo but mine is the sensor in the dash my speedo works but it flips back and fourth so fast i cant read it
Frozer!!!
Jan 19, 2024 04:55 PM
Wylecoyote08
Nov 6, 2015 03:46 PM
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
