changing auto to standard
Old Nov 8, 2008 | 10:56 PM
badass91's Avatar
i just changed to 5 speed cant find the console pieace shifter boot i was thinking about taking my auto one an making one any one else did if so can i see pics
Old Nov 8, 2008 | 11:37 PM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
Re: changing auto to standard
Yep, I did it.
Do you have a Camaro or a Bird? I couldn't find a manual shifter plate anywhere for a bird, so I just cut out the gear selector part to open the hole up big enough. I also had to bend the shifter into a slight "S" shape to keep it from hitting the top plate. I hand stitched the boot from cheap black vinyl from Wal-Mart and attached it to the original screw mounts on the bottom of the plate with a bracket that I fabbed from sheet metal.
I eventually ended up swapping in a 4th gen 5spd console....much nicer than the original console.
Pics are in this thread:
https://www.thirdgen.org/forums/inte...ual-upper.html
Old Nov 10, 2008 | 10:22 PM
badass91's Avatar
ya i got a camaro
Old Nov 11, 2008 | 03:12 PM
FYRCHKN's Avatar
Engine: LT-1
The part is called a shift plate. There are usually Camaro ones all over ebay.
Or you could try gmpartsdirect.com
Old Nov 12, 2008 | 12:05 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
PM me, I have a Camaro 5 speed manual shift plate for a 3rd gen.
Frozer!!!
Jan 19, 2024 04:55 PM
jklein337
Sep 19, 2018 06:23 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
theshackle
Aug 23, 2015 03:49 PM
jbd1969
Aug 17, 2015 07:06 PM
