Simple question: Manual upper shift boot
Old Feb 21, 2008 | 07:42 PM
Bandit5's Avatar
I am putting a manual transmission in my formerly automatic car. All I need now is the finishing touches. I just got a manual shift plate from eBay and a new upper boot from Hawks. I can see how the boot appears to go in, but it looks like I need a rectangular plastic piece that screws into the shift plate and clamps the boot into place... is that correct?
Please help me get this thing in. If it is what I think it is, I am going to have to rig something up.
Old Feb 21, 2008 | 08:07 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Simple question: Manual upper shift boot
thats about right, the rectangular piece is actually metal. Ive never seen just that part for sale anywhere. Maybe try ebay or something
Old Feb 21, 2008 | 08:08 PM
Bandit5's Avatar
Can someone show me a picture of one? If I can't find one, I can probably just make it.
Old Feb 21, 2008 | 10:09 PM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
When I did my auto to manual swap I couldn't find a manual shifter plate, so I "modified" my auto plate. I also made a bracket to mount my home made shifter boot to the modified shifter plate. My bracket is made out of 24 ga. sheet metal.
Attached Thumbnails Simple question: Manual upper shift boot-shifter-plate-004.jpg   Simple question: Manual upper shift boot-shifter-plate-005.jpg
Old Feb 21, 2008 | 10:21 PM
Bandit5's Avatar
Ok, thanks. I will buy the sheet metal tomorrow and fashion it into shape by the evening.
Old Feb 21, 2008 | 10:57 PM
FYRCHKN's Avatar
Engine: LT-1
I forgot to add that I used two pieces of sheet metal. I had to sandwich the boot between the two pieces to keep it in place.
Old Feb 22, 2008 | 12:06 AM
Bandit5's Avatar
I have a manual shift plate, just missing that piece. I believe if I create something similar to what you have done, only with 90* bends over the sides, it will hold it in place just like the stock piece would. If that doesn't work, I will use your idea and sandwich it with two pieces. Thanks!
Old Feb 22, 2008 | 05:52 PM
Bandit5's Avatar
Well, I spend about an hour or more working on piece of steel to use. I basically did complete it, but in my haste I took off too much material from the interior of it and also cut off a piece that I had wanted to bend. I ended up with a piece that could work with some creative mounting.
However, in the middle of mounting the boot with the plate, I got frustrated with the whole thing and decided to try something else. I had a clam clip dispenser in the office that I've never used. Thought this might work out as a temporary fix until I get the factory piece. But it seems to work much better than I had anticipated, that I will probably just keep it permanently.
Attached Thumbnails Simple question: Manual upper shift boot-p1010481.jpg   Simple question: Manual upper shift boot-p1010482.jpg
Old Feb 22, 2008 | 08:38 PM
FYRCHKN's Avatar
Engine: LT-1
Nice job.
Old Feb 22, 2008 | 11:02 PM
NowTheBadNews's Avatar
Car: 2006 Ford Mustang
Engine: 4.0 V-6
Transmission: Automatic
Axle/Gears: not sure
15 bucks shipped for the thing your missing
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
F-body driver
Mar 6, 2023 11:44 AM
FormulasOnly
Sep 6, 2015 10:42 AM
BOOT77
Sep 5, 2015 03:55 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
