cruise control no work?
Old Nov 16, 2008 | 12:50 AM
racerx520's Avatar
for almost a year now my cruise control hasnt worked, ive checked to make sure the wires are plugged in, i puta new vacuum hose on it from the vacuum chamber and that didnt help....everything is hooked up properly but it doesnt work....also when i squeeze the diaphram on the cruise control ihear it whistle, is that supposed to happen? is maybe there something wrong with the vacuum within the cruise control or is the unit just broken?
Old Nov 18, 2008 | 08:58 AM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
Re: cruise control no work?
Im not a pro at cruise but I know that the actual diaphram will whistle a little but check the canister for leaks. I fixed my fiero's cruise control by finding a couple rust holes in the vacume canister and I just cleaned it and painted it with under body coating (rubberized). I think my 92 has the same problem but I have been to busy to even fix my air dam so cruise is not a top concern but I would have to put my money on a leak at the canister also since I checked everything else.
Old Nov 18, 2008 | 11:27 AM
racerx520's Avatar
how would a hole develop in the vacuum canister? i thought it was plastic and hidden away in a safe spot that nothign coudl happen to it....atleast it seems hidden away
Old Nov 18, 2008 | 12:23 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Guessing: shot servo (IIRC, I've had four remans in my car) or cruise control module, VSS problem, vac leak at the brake pedal.
JamesC
Old Nov 18, 2008 | 07:10 PM
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
not all are plastic
Old Nov 18, 2008 | 08:14 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Also check the vacuum hose.
Old Nov 19, 2008 | 11:35 AM
racerx520's Avatar
i replaced the vacuum hose already, it wasnt in bad shape but i had left over hose so i figured i'd give it a try
eightsixseven
Dec 16, 2024 01:50 PM
Street Lethal
Aug 13, 2015 08:28 PM
stalkier
Aug 13, 2015 12:59 PM
Street Lethal
Aug 12, 2015 11:33 AM
Bull86
Aug 10, 2015 05:43 PM
