How to remove air bag stering wheel
Old Nov 20, 2008 | 02:33 PM
Gibbyzracing's Avatar
Car: 91 RS Vert 86 Cutlass
Engine: Sbc
Transmission: T5 400 Turbo
I have a 91 RS convertable. i am wanting to remove the air bag stering wheel. I want to put a nice aftermarket one one it. Can anyone here tell me the best and easiest way to do so. Maybe include pictures also.
Old Nov 20, 2008 | 11:23 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Re: How to remove air bag stering wheel
Pull the SIR fuse from the fuse box, then disconnect the yellow connector at the base of the steering column which will be labeled SIR system so the airbag doesn't blow in your face. Then remove the 4 bolts from the back of the steering wheel which will allow you to remove the air bag. Disconnect it's wiring and set it aside. Now you need a steering wheel puller. First remove the hex nut and use the puller to yank the wheel off it's shaft. Just so you know, removing air bags is illegal and probably not a good idea if your state has mandatory safety inspections.
Old Nov 22, 2008 | 09:07 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
It is illegal, however, rarely enforced. If you look on the V.I.N. tag affixed to your dash (Visable through the windshield) it says "Air bag" on it. GM and other manufacturers did this to discourage people from removing them.
That said, do it, but keep the parts to convert it back. Selling the car down the line with the system removed could open you up to a lawsuit if someone is killed or injured down the line.
Good luck.
Old Nov 22, 2008 | 11:35 PM
RevItUpZ28's Avatar
Car: '91 Camaro Z28
Engine: 383 Vortec HSR
Transmission: Pro-Built 700-R4;Vig 4000 stall
Axle/Gears: Moser M9 9" / 3.89
Good luck.
To go along with that, you might want to check with your insurance company before switching wheels. If its insured as having an airbag and your remove it, they could refuse to pay any claims if you get in a wreck and get injured.
Old Nov 23, 2008 | 01:54 AM
I didnt even think of that!
Old Nov 23, 2008 | 12:10 PM
Engine: Sbc
Thanks for the help guys. Its under custom car insurance. The car will be a show car when Im done and go to the track every now and then. I just cant stand the air bags. I am thinkin of putting the late 80s Iroc Wheel on it I like it better.
Old Nov 23, 2008 | 12:49 PM
If you are going the showcar route, I would highly recommend something from lecarra, momo, budnik, billet specialties, etc.
They arent that expensive and look great!
Good luck!
Old Nov 23, 2008 | 01:56 PM
Engine: Sbc
Im not too sure what I am going to do. This will actually be the first show/race car I have built with out a stock stering wheel. But I just hate the air bag ones. My 7 sec nova has the factory Nova SS stering wheel on it still lol. Can you guys post up some pics of what aftermarket stering wheels you have
Old Mar 28, 2011 | 11:28 AM
Stonehenge's Avatar
Car: 1989 5.7 IROC Dark Red/Blk 92Z28
Engine: 5.7
Transmission: 700R
I wouldn't remove it if I were you, but if you do.. here is the wheel that will be on my 87 IROC.. easy to install, nice looking, not too expensive..
Stone
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
