Interior Lighting/Fuse Block
Old Nov 25, 2008 | 05:12 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Info: I have a 1989 camaro rs; my interior lights wont turn on and along with that my fuse box doesn't have a cover and the cover had the fuse box list of which fuse goes to what (i believe).
Need Help With:
Which fuses do what?
Anyone have a diagram of where all the fuses go?
I'm thinking of buying all new fuses; but i'd like to know what fuse goes to what and how many amps each one should be.
regards,
Timinsk
Old Nov 25, 2008 | 05:30 PM
FireChicken2.8's Avatar
Car: 1989 Red T-Top Firebird, 1989 Iroc
Engine: 2.8L 173 C.I., 355
Transmission: Th700r4 Auto, Built TH700R4
Re: Interior Lighting/Fuse Block
If you have your owner's manual still there is a handy little picture and labels for all the fuses.
Old Nov 25, 2008 | 09:23 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Do your radio and lighter socket work? If they do, your problem is in the wiring, not the fuse, because the fuse for the interior lights (I'm assuming courtesy lights, correct me if I'm wrong) is the CTSY fuse, which is a 15 amp (blue) fuse right in the middle of the fuse block, next to the circuit breakers for the power windows. Your fuse panel is also labeled as to what fuse is what. However for your convenience, if it will fit, I'll attach a diagram of the fuse panel. In the diagram, the fuse labeled (ACC) is the one for your interior lights.
Attached Thumbnails Interior Lighting/Fuse Block-fusedata.jpg
Old Nov 26, 2008 | 10:33 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Check your door pins. they get corroded over time and many times can be removed, cleaned and re-installed to correct courtesy light problems.
Old Nov 26, 2008 | 10:48 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
thank you everyone for helping; this helps.
btw my radio is removed and my lighter ive never tried; but its really mangled.. so its hard to tell.
Old Nov 26, 2008 | 11:18 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
"PWR ACC"?
or
ACC 20-20 from what i see on the diagram
Old Nov 27, 2008 | 11:55 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
I replaced the fuses; and noticed the acc was shot and kid had a 10 amp in it when it was suppose to be 20 and i replaced it but now my interior lights stay on always; how do i turn them off?
Old Nov 28, 2008 | 04:15 AM
alicat's Avatar
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
Check your headlight ****.If it's turned hard to the left,the interior light will stay on.Thats how it is in my 85 Z.
Old Nov 28, 2008 | 08:40 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
Ooh ok; I'll try that.
Old Nov 28, 2008 | 05:33 PM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
I turned my **** all the way to the right and the lights went off; that helped so much. I didn't expect that really. But I notice my dome light doesnt go on. So i'm going to recheck the fuse once I get out of work.
Old Nov 28, 2008 | 10:55 PM
alicat's Avatar
Axle/Gears: Stock.
Also the headlight **** is the dimmer for the instrument panel lights,so if you leave it fully to the right they wont be on.I just leave mine to the left,but not fully.Your dome light globe may be blown,or the door pins may be sticking.
Old Nov 29, 2008 | 06:38 AM
Timinsk's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Axle/Gears: 3.23 LS
I'll recheck because I kind of freaked. I installed all new bulbs and then i looked and realized the person who owned teh car before me put a 10 amp into the acc so it was already shot and i replaced it with a 25 amp or it was 20... but anyways i replaced it and didn't realize it until i got home (10 hours later) that my lights were on (it was around 11pm) and i just got a new battery for it before that.. so i unplugged the battery and then replugged it while i had the **** turned all the way to the right and it turned them off but when i turned them on my dome light doesnt come on; the lights went off when door closed so i know that the pins work, ill recheck bulb when i get home.
thanks again everyone!
Hawk312
Aug 22, 2017 08:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Ducati900ss
Sep 2, 2015 09:05 AM
gixxer92
Sep 1, 2015 04:32 PM
theurge
Aug 21, 2015 12:46 PM
