4th Gen Dash question
Old Dec 18, 2008 | 10:11 PM
ERICSCHEVY's Avatar
Car: 82 Camaro Z28
Engine: 305 Crossfire
Axle/Gears: 3:23
Just purchased a 98 Camaro dash. My question is the gauge cluster is from a V-6. Will this work on my V-8 ?
Old Dec 19, 2008 | 09:52 PM
ERICSCHEVY's Avatar
Car: 82 Camaro Z28
Axle/Gears: 3:23
Re: 4th Gen Dash question
Also, Should I install the new dash before or after I put my Lt1 in ?
Old Dec 20, 2008 | 04:44 PM
ERICSCHEVY's Avatar
Car: 82 Camaro Z28
Axle/Gears: 3:23
Ah come on... no one ??????
Old Dec 21, 2008 | 03:10 PM
ERICSCHEVY's Avatar
Car: 82 Camaro Z28
Axle/Gears: 3:23
Wow !! Did the support on here come to a halt ? I've always had good response time in the past, just curious, I'll keep trying, (seems kind of odd talking to myself on here,lol).
Old Dec 21, 2008 | 04:10 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Yes the cluster will work fine. But your tach will be off because it is for a V-6. Other then that your golden. I am not sure about the 3.8 but with the ls1 clusters you need to do a little extra work to get everything working right. Keep in mind you can swap a cluster from a bird dash into that with no problems.
I am no expert on LT1 swaps but that shouldn't matter at all.
Last edited by The_Wraith; Dec 21, 2008 at 04:12 PM. Reason: Automerged Doublepost
Old Dec 21, 2008 | 05:54 PM
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Old Dec 21, 2008 | 09:18 PM
ERICSCHEVY's Avatar
Car: 82 Camaro Z28
Axle/Gears: 3:23
Thanks guys ! Appreciate the feedback.
Old Dec 26, 2008 | 09:59 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
tach will be off as mentioned, but the 98 isnt going to mate well with the lt1 harness.
youll need a 97 camaro cluster, or a 93-97 bird cluster.
Old Dec 27, 2008 | 02:30 AM
ERICSCHEVY's Avatar
Car: 82 Camaro Z28
Axle/Gears: 3:23
Will the 97 Camaro cluster fit ? Does it look the same ?
Old Dec 27, 2008 | 12:24 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
the 97 camaro looks just like the 98-02 camaro cluster, but you can wire in each gauge whereas the ls1 stuff gets a bit tricky in some areas.
in your case, your lt1 harness will plug right in if you get the interior harness along with your swap.
Old Dec 27, 2008 | 01:17 PM
white91formula's Avatar
Car: 91 formula
Transmission: t5
i would take out the old dash, do the swap and run your wiring and then put the new dash in or your going to have a nightmare running wires.... also like said above try to get the in car harness so its plug and play
Old Dec 28, 2008 | 09:33 AM
The_Wraith's Avatar
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
You might get lucky I hear bottom end of 97's are fully compatible and that includes digital odometer. As for the LS1 cluster like I said above it can be made to work.
Old Dec 28, 2008 | 04:22 PM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
I've got a 94 ta cluster that I was going to cut up to use the warning lights.(I have autometer guages) If you want it I'll trade you for the 6 cylinder car cluster. you pay shipping both ways.
Kory
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Casey Meyers
Mar 2, 2016 10:46 AM
redmaroz
Aug 16, 2015 11:40 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
