Freakin dashpad OMG read this
Old Feb 11, 2009 | 06:50 PM
tgk7203's Avatar
Ok so I did my reaserch found out about the four screws near the defrost vets. So I look under the daspad and see the screws ok so I remove them and dashpad goes no wear. I am about to just rip the thing out so I figure I will read this site agian. After around 30 threads I seeb this thing called a dash pad cap or coverso wtf is this so I go look carefully at mine an boom like a bolt of lightning. Ok so now how does this come off. well I tried to pull it off and its tuck so I tried to find out why it was stuck. So I tried to lift it up and rip crack oh shiznit well gone this far so screw it. Finally see the correct screws and now the old dash pad is gone now we need to find a new dash pad. Wow that was insane p.s. I also cut one of the dash suports Becuase I could not reach the nut dam it.
Old Feb 11, 2009 | 06:58 PM
Ca[maro]88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
Re: Freakin dashpad OMG read this
dude i just pulled all the bolts out of the bottom.. took the 4 vent screws out and pulled it off.. it took no more than 5 minutes. ive had mine on and off like 20 times and never cracked it. you must have been missing a bunch of bolts or something..
Old Feb 11, 2009 | 07:02 PM
Bruce91RS's Avatar
same here.....in and out no prob.
Old Feb 11, 2009 | 08:58 PM
tgk7203's Avatar
there was a cap thing covering those four bolts a hard plastic dash coverso i could not see the bolts and seen some underneath and tried removing those
Old Feb 11, 2009 | 09:46 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
Sounds like you missed the screws that are underneath the edge of the dashpad. The 4 vent screws arent the only thing holding it down...
Old Feb 11, 2009 | 09:52 PM
Phishman92's Avatar
Car: 92 25th Anniversary Z28/RS
Engine: 305 TBI.... (for now)
For future reference, when you get to the point where you're using phrases like "O shiznit" "Freakin" and "OMG"...it's time to walk away
I'm sure we've all made a mess out of a really REALLY simple job when frustrated, so lesson learned there.
Other than that, yeah the dash pad is cake as long as you take your time finding the bolts. You'll be able to take them in/out in no time now.
Old Feb 11, 2009 | 10:55 PM
tgk7203's Avatar
got all from underneath and the front would lift up but the daspad cap was covering the four bolts on top and I didnt realize the cap thing wasnt factory
Old Feb 11, 2009 | 11:58 PM
82Five-O's Avatar
Car: 82 Sport coupe
Engine: 355 semi roller
Transmission: TH-350 B&M ratchet shifter
Axle/Gears: 3.73 Eaton Posi
I think you just took the boards longest run-on sentence award...
Old Feb 11, 2009 | 11:59 PM
82Five-O's Avatar
Car: 82 Sport coupe
I think you just took the boards longest run-on sentence award... oh wait you did use periods i see em now.
Old Feb 12, 2009 | 10:45 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
you cut a dash support because you couldn't reach the nut? that's a big no-no. Looks like you'll be shopping for a new dash pad and dash shell. It really REALLY pays to take your time and remain patient. As Phishman92 said, we've all broken things when we've been frustrated and didn't take a break to recollect our thoughts and emotions. And breaking something will get you even more frustrated. For the future, install a little switch in your head that makes you turn off and walk away for 10 minutes whenever you reach for a hammer, pry bar or decide to use any other form of brute force!
Old Feb 12, 2009 | 03:17 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Yeah, Ive done stupid stuff before and got pissed and broke stuff too. Now after working on these cars long enough I know when its time to take a break. come back in 15 min and everything will usually be easier
Old Feb 12, 2009 | 03:22 PM
Ca[maro]88's Avatar
yeah youll be mad when you cant get the dash pad out but youll be REALLLLLY mad when you gotta for over 120 bucks for a USED one. only thing ive had to replace so far a windshield wiper lol.
Old Feb 16, 2009 | 12:05 AM
chindo's Avatar
Car: 1976 Trans An
Next time your tuggin something and it wont come out take a stp back and scream as loud as u can, it will help cool you off. The dash has prob like what 10 screws at most. easy to miss them if your head is spinning at 6500 RPMs.
Old Feb 16, 2009 | 10:19 AM
tgk7203's Avatar
the one thing I forgot to minchin is that there was a cover on the dash pad it was like abs plastic and i could not see the screws on top by yhte vents becuase they were covered plus some one glued this cove on the original dash so when u remove the cover the dash is destroyed
Bubbajones_ya
Jul 6, 2024 08:32 PM
sahlomonic
Sep 20, 2015 07:15 PM
eustodp
Sep 20, 2015 05:09 PM
Rally Smith
Sep 14, 2015 06:59 PM
sandman92084
Sep 12, 2015 10:27 PM
