speedometer cluster
Old Mar 5, 2009 | 02:48 AM
89RSCAMAROMAN's Avatar
Car: 1989 Camaro rs
Engine: TBI 305
Transmission: t5
Axle/Gears: 3.08
speedometer cluster
a friend bought a 87 z28 and the speedometer cluster in it is a 145. he stripped the car and i took the speedometer off. well the mileage gears and everything where screwed up so i just took the needle off and took off the speedometer plate that has the numbers on it. so my question is can i put this place in place of the one in my 89 camaro that reads 110. will my speedometer still read okay and all that?
Old Mar 5, 2009 | 05:39 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: speedometer cluster
Welcome to TGO. Yes. Recalibration after removing the needle may be a problem (frankly, I'm amazed that you managed to get if off without breaking it). I'd recommend swapping the speedo head into your cluster, if your cluster functions as designed. Check the following link for other considerations:
https://www.thirdgen.org/forums/faq-...-fix-pics.html
JamesC
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
