Will this steering wheel fit?
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
Will this steering wheel fit? If not what adapter can I buy to make it fit?
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Re: Will this steering wheel fit?
Well it looks like a rip-off of a Grant steering wheel. Juts get he Chevy hub adapter and it should fit no problem.
Car: 1984 Camaro
Transmission: 350 Turbo
I actually Bought that exact same stearing Wheel for my 84 camaro off of ebay.
When I tried to remove my old one it almost seems as though the current one is possibly welded on, all i know is that its not going to be very easy to take off.
If i can manage to get the stock one off It looks like the apc wheel should fit, or mabey It will need that chevy hub adapter or whatever. Not sure yet.
Car: 87 GTA
Its not welded on.....You just need a steering wheel puller (any Autozone/O' Riellys etc.) to get it off. That center ring will come off with the welded pieces.
Car: 1984 Camaro
Thanks for letting me know. The odd staggered bolt pattern in the center of the wheel looks as though it matches whats on the Wheel that I bought so i figured that I might be able to just bolt it on if i got the old one off of there but I guess that whole center peice is one part and all comes off. Meaning I will likley need to get that adapter or whatever to get it on.
Car: 89 RS
Engine: 305 TBI (lo3)
Axle/Gears: Whatever is stock.
Engine: 355/350
Car: 83 Pontiac Trans Am Recaro
Engine: Crossfire 350
Axle/Gears: 4.10 posi
Grant Steering Wheel Adapter Part # 3162 according to my old parts catalog... any advance auto, auto zone, or O'reilly's should be able to hook you up with the right one...
Car: 89 RS
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
My adapter kit was part #3196 and I have that same wheel but silver spokes.
Here is the difference between the 3196 kit and the 3162 kit mentioned above
#3196
Does not fit telescopic steering column.
#3162
Will fit TSC (Doesnt say it won't so I figure it will)
#3196
#3162
Engine: 355/350
May be a dumb question but whats a telescopic steering column?
Car: 89 Iroc Convertible
A telescopic steering column is one that you can pull out towards you or push in towards the dashboard just like a telescope.
backtothe80s
Sep 5, 2015 12:39 AM
