Firebird Console Lid...Return spring
Old Apr 29, 2009 | 08:48 PM
Firm's Avatar
Car: 84 Camaro 2.8L, 85 T/A 305 LG4
So I took the console lid off the '85 a month or so ago to recover it, now I just went to put it back on and I forgot how the stupid spring loaded thing goes back inside the console.....You access this by removing the rear ashtray. Could someone describe how this should go back, or remove their rear ashtray and snap a pic.
Old May 1, 2009 | 04:06 PM
Firm's Avatar
Re: Firebird Console Lid...Return spring
Bump. Still can't remember how this goes.....anyone?
Old May 1, 2009 | 06:25 PM
Net-Viper X's Avatar
Car: 91 Bird w/Aero Pkg - 02 T/A Col Ed.
Engine: 5.0L - 5.7L Ram Air
Hello, I dont have a camera at the moment to take an adequate pic, but I would certainly recommend removing the entire console so you can put that coil back in from the bottom. Trying to put it in through the Ash tray slot is doable but extremely difficult, I had hell doing it this way. Since those springs seem to break every few years, I bought a box of extra replacements and do it every 2-3 years. Once you get the console off and look at it, its pretty obvious how it goes in.
Their are two holes the spring goes in, one mounted with a metal clip to the inner console, and the other hole is in the arm coming from the lid. Put the spring into the console clip hole first, then you have to kinda twist it back onto itself to get it in the hole in the lid arm. Seems like the lid has to be about half open to get it in right. I hope this makes sense, I suck at describing things in text. If I was there I could put the thing in for you in about 10 seconds.
When I get my camera back, if this thread is still floating around unresolved, I will snap a few pics for you.
Old May 3, 2009 | 10:11 PM
glock's Avatar
Car: 1989 gta
Engine: L98 D1SC procharger twin IC
where do you buy the return springs ... mine just broke and i cant seem to find them ...are they all the same spring? i have a 89 gta
Old May 6, 2009 | 09:37 AM
Firm's Avatar
Thanks for the description viper......I'll try again with your description on the weekend and report back.
I took some pics for another forum, so I might as well throw them up here too.
Heres the spring I am reFering to:
The open lid.....note the metal arm going through the hole in the console:
And here is the area i am talking about behind the rear ashtray.....You can see the metal arm coming through the top oF the console....what I need to know is how I am suppose to connect the spring to the end oF this arm.......Even iF someone could pull out their ashtray For me(only two screws) and snap a pic oF this area that would be very helpFul.
Thanks guys
Old May 6, 2009 | 07:04 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
It's not easy, and you can't just do it through the rear ashtray hole. You have to have the console upside down with the lid closed to get it right. I used to have a working one. I'll see if I can't come up with something a little more concrete when I have my day off on Friday, but that's all I remember. The Camaro console is set up the same way with the same spring and all, just in a different direction, if you happen to know someone with a working one, it will help you go in the right direction.
BTW, nice fix for the console lid. What size staples did you use? I tried that with my original, which was too broken to fix, I guess.
Old May 6, 2009 | 07:32 PM
Firm's Avatar
Well that sucks.....How difficult is it to remove the console??
I don't really remember what size staples those were....but the trick is to staple to the outter edge thats soft enough to receive the staples.
Old May 6, 2009 | 07:35 PM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
Not hard. The hardest part for me was actually pulling the wire off the cigarette lighter lol. Just pull the C clip out of the shifter **** and take it off, then start unbolting and unplugging wires. Be careful with the plastic parts i.e. shifter plate and window switches. And remember where everything goes back!
Old Apr 17, 2016 | 08:02 PM
soulreaper's Avatar
Car: 91 Firebird
Engine: 3.1L V6
Ever find these springs? I have been looking for one and can't find anywhere.
Old Apr 19, 2016 | 08:54 AM
bop11's Avatar
Car: 1988 GTA
Engine: VIN F 305 TPI
Transmission: AUto
Just a note, if you break the flat part of a window switch or want to rebuild a boss for a screw, that UV setting glue you see on TV ($19 for one but you get 2) or in the drugstore ($9 for one) works very well and very quickly. Where you would have used epoxy in the past, this stuff sets up hard and fast and can be filed and sanded. We used it to put some of the bosses back on the plastic that holds the top pad and a flat part around a window switch. It seems to be holding up without a problem. Just a thought.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
Casey Meyers
Mar 2, 2016 10:46 AM
Dialed_In
Aug 20, 2015 01:45 PM
TheJoeY88
Aug 13, 2015 06:51 PM
