dash ideas
Old Jun 17, 2009 | 02:31 AM
JWA88TA's Avatar
Car: 88 Trans Am
dash ideas
i have a 88 ta with digital gauges that i hate is there any body that has or know how to make something to fill all of that up. One thing i had in mind was to do some searching for manual cluster the ones that just have the four 5 inch holes and put them in because i really like how they look but would wiring them up to work be very difficult.
Old Jun 18, 2009 | 07:22 AM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
Re: dash ideas
easier to swap from digital to analog. just need harnesses and bezels i believe. some soldering of wires. you can search for more info.
Old Jun 18, 2009 | 09:51 PM
JWA88TA's Avatar
Car: 88 Trans Am
Re: dash ideas
would i still need the harness if i put aftermarket gauges in there ive seen some that have a 5 in. tach and 5 in. mph gauges on either of the column and and the gas gauge right up above the column toward the top pf the panel, and the other two holes they cut out making it 1 big oval shaped hole and has other gauges they you would want and need. just asking that becasue not sure if they i would the harness i know some gauges have there own sending units but i could totally wrong thats why im asking!
Old Jun 21, 2009 | 03:49 AM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
Re: dash ideas
if your putting after market gauges keep the harness you have but get a book for your car that has teh correct wiring diagrams
goodluck
Old Jun 21, 2009 | 10:14 AM
rideon1200's Avatar
On Probation
Car: 2002 Formula
Engine: 5.7 LS1
Re: dash ideas
Wow, first time I have seen a digital to analog conversion. Have heard people spending alot of time and money going from analog to digital...... Digital looks a hell of alot better, cleaner........
Old Jun 21, 2009 | 10:54 AM
strc09's Avatar
Car: 1988 Pontiac Firebird Trans AM GTA
Engine: Tune-port Injected 6.3L
Transmission: Borg-Warner T56 six-speed
Axle/Gears: Borg/Warner 9-bolt with 3.70:1
Re: dash ideas
Digital = PITA. I have it and I hate it. t was cool when I first got the car, but after having it I don't care for it anymore. Everything but the speedo is not as accurate as analog gages. I've been comtemplating doing this myself, but going mechanical instead of electrical gages.
Old Jun 23, 2009 | 01:42 PM
JWA88TA's Avatar
Car: 88 Trans Am
Re: dash ideas
yeah i cant wait to get some parts and start to see what i can come up with, half of my digital gauges were broke and busted but that what you get when you get a car for $800
toones
Jan 6, 2016 06:00 PM
1Aauto
Sponsored Vendors
Nov 23, 2015 02:17 PM
Jk_Under
Sep 2, 2015 10:59 PM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
