Are t top headliners available?
Old Jul 3, 2009 | 03:42 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
I am looking for t top headliner. Are they available? How about the reproduction types? anybody have any experience with these?
Old Jul 3, 2009 | 05:25 PM
lordmetalz28's Avatar
Car: 1987 Z28 with iroc-z Package no.3
Engine: 350TPI
Axle/Gears: 3.73 posi
Re: Are t top headliners available?
yes there available.. you can pick one up pretty much any place that deals with camaro parts and resto.. the new ones are abs plastic and the fitment is not that great.. but its all thats out there... pick up some heavy duty velcro to help you along a little the section behind the t-tops likes to sag a little.. and if you have a roof console be prepared to do some cutting..
Old Jul 3, 2009 | 06:04 PM
Thanks for the info. You say they don't fit well? And yes, I have a console. It's an 86 iroc. Someone told me they can apolster the cardboard that's behind the crumbling foam. The cloth is so decayed, it tears easy. I thought of making one of my own. If the "cardboard" can be covered, then I was thinking of using my old one as a templet.
Old Jul 3, 2009 | 08:38 PM
Engine: 350TPI
my buddy has the twin to my car and he had a professionall interior guy do his the same guy that did my seats.. and the headliner looked far worse then the ones they sell... but it all depends i guess.. good luck whatever way you decide to go..
Old Jul 3, 2009 | 08:40 PM
Engine: 350TPI
the fitment issue i mainly had was behind the tops it sagged a lot... so i used a bunch of heavy duty velcro and that helped.. but it still left me with some white body showing because the headliner didnt sit flush with the roof.. i used some push on edge trimming in black and now it looks great..
Old Jul 3, 2009 | 09:00 PM
Are they a pain in the butt to install? What is push?
Old Jul 3, 2009 | 11:14 PM
Engine: 350TPI
thier not to bad as long as you have the right tools.. i recommend a dremel cutting wheel makes cutting thru that plastic a breeze so you dont make a mistake.. push is the push on molding ( door protecters) i pushed them on the the back roof rail to make things a bit neater back there
Old Jul 5, 2009 | 04:48 PM
Net-Viper X's Avatar
Car: 91 Bird w/Aero Pkg - 02 T/A Col Ed.
Engine: 5.0L - 5.7L Ram Air
Before you spend some money, check out the tech article about T-top headliner repairs. I did what this guy explains only I covered my entire headliner with fiberglass sheet instead of just the edges to make it extra sturdy.
If the fiberboard backing (yellow stuff) is still in one piece then this fix works fine, and you dont have to worry about the thing not fitting right since its the factory liner. Doent matter if the backing is cracked here and there since the fiberglass sheet will hold it together.
Here is the link
https://www.thirdgen.org/headlinerrepair
Old Jul 5, 2009 | 05:06 PM
Thanks. I will read through it and see if it's for me. Gotta do something. GM really ****** up when they produced these, and then not have any in stock any more... They must not have expected the third gens to last this long or something.
Old Jul 6, 2009 | 01:26 PM
1Aauto's Avatar
Former Sponsor
HI here's a link to our ABS T-Top Headliner kits. Being on the ABS board the ABS will not deteriorate like the factory one.It's allot sturdier too so you do not need to reuse the headliner clips.
Here's a link to them on our site.
Camaro ABS Headliner
Old Jul 6, 2009 | 03:00 PM
Engine: 350TPI
If this is the one im thinking of its made by acme correct.. i purchased one from you and tried to get in contact with acme.. they really need to redesign it these dont fit so well.. but no contact info on them
Old Jul 6, 2009 | 03:08 PM
1Aauto's Avatar
Former Sponsor
Yes we sell the ACME ones.They're a great company and have been around since 1948.I do know that they put allot of time into developing their products.
If your stilll having an issue with it give me a call and I'll see if it has anything to do with the way it was installed, and what the problem areas are, and if there's a solution for it.
Tony
Old Jul 6, 2009 | 03:34 PM
1Aauto's Avatar
Former Sponsor
UPDATE:
I called the manufacturer,all of these headliners are cut exactly the same, so the trick that I was informed of is, when you install the new ABS headliner loosly install the dome light.That way you can slide around and adjust the headliner to line up with the sunvisors and place it where it needs to be. If you tighten down the dome light first, it'll make it harder for you to shift it into position. Once you have everything lined up then tighten down all of the retaining points.
Hope this helps,
Tony
Old Jul 6, 2009 | 05:46 PM
Engine: 350TPI
UPDATE:
Hope this helps,
Tony
yeah lining up was never the problem.. but i do appreciate your help. the sag behind the t-tops was always the problem but i remedyed i tlast summer with some velcro and it looks decient now.. but thanks for standing behind your products.. something classic industrys would laugh at me about.. thanks again
Old Jul 6, 2009 | 06:55 PM
adriancamaro's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: T5 WC
Hey Stevolwevol If you need a headliner, i have a red one with the console and its perfect. you could just recover it with whatever color you need. Let me know, id be willing to sell it to you.
Old Jul 6, 2009 | 07:34 PM
Mmmm what ya want for it?
Old Jul 6, 2009 | 09:01 PM
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: T5 WC
I just bought mine for $180 plus shipping. make me an offer.
Old Jul 6, 2009 | 09:31 PM
which one did you buy? one of the abs covered, or uncovered?
Old Jul 7, 2009 | 07:56 AM
1Aauto's Avatar
Former Sponsor
Not a problem at all. I hadn't heard about the middle sagging but that seems like a quick easy way to take care of that issue,and now you have a headliner that will last forever.
I want you guys to be happy with whatever you buy from us so if there's ever an issue with a product I'll find a solution for it.
For those of you that would like to recover your original fiber board we do sell a scrape and recover kit too. Here's a link to the material on our site.
Hope this has helped,
Headliner Scrape And Recover Kit
Old Jul 7, 2009 | 09:09 AM
1Aauto's Avatar
Former Sponsor
Another update on this, I had the directions to the ABS headliners for both the console and non console T-Top cars added to our site.
The printable instructions are right in with the product,and it walks you through on how the manufacturer recommends the console be reinstalled into your thirdgen car if it was equipped with that option.
We like to make these things as simple as possible for you guys.
Tony
Old Jul 7, 2009 | 10:19 AM
Thanks for th info. I will look into this.
Old Jul 7, 2009 | 11:53 AM
1Aauto's Avatar
Former Sponsor
You're welcome
Old Jul 7, 2009 | 06:10 PM
A bit off topic, but man 1ATony, thats what I call super helpful service. I know a few vendors that could sure learn a thing or three from you about how to run a business. My hats off to you!
Old Jul 7, 2009 | 10:24 PM
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: T5 WC
i bought the abs covered one from hawks third gen parts. Just ordered it and they are closed til the 12th so ill let you guys know when it comes and how it was installing it.
Old Jul 8, 2009 | 02:17 PM
Is this going in your RS? I have a council to work with. My RS does not have one. I suppose I could leave it out, but I kinda like it, even though it's next to worthless. Keep me posted on installation.
Old Jul 8, 2009 | 10:11 PM
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: T5 WC
Ya i ordered one for my RS because it doesn't have a console, but the red one is in my 1985 Z28 and it has a console, the one out of my 85 Z will fit perfectly into your car. let me know if you want it, and how much you want to pay for it. i don't want to pull it out of the car if you don't want it, so just let me know.
Old Jul 9, 2009 | 01:55 AM
The headliner I need is my 86 iroc which has a council, and I would like to re install it with a new headliner. as for thaking it off your hands, let me know PM.
Old Jul 9, 2009 | 11:22 AM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Make sure you get one that has an ABS plastic backing so that in a worse case scenario you can just have that recovered rather than losing the whole piece.. i regret that i cannot tell you where to find one.
Old Jul 10, 2009 | 03:22 PM
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: T5 WC
Is it possible to recover a headliner with the yellow foam backing innstead of the plastic backing?
Old Jul 10, 2009 | 03:25 PM
1Aauto's Avatar
Former Sponsor
Do you mean recover the stock fiberboard?
Old Jul 10, 2009 | 04:19 PM
How do you remove the council? I looked but I cannot find screw. I am thinking they are removable from the underside.
Old Jul 10, 2009 | 05:17 PM
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: T5 WC
Ya can the stock fiberboard ones be recovered?
And I dont know how to take the center console out, I haven't tried yet. I want to make sure it can be recovered before i sell it to you, and if it can then i will take it out.
Old Jul 10, 2009 | 07:12 PM
How does the t top feel under the fabric? are there any chunks missing?
Old Jul 11, 2009 | 04:52 PM
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: T5 WC
No there are no pieces missing, and as far as i can tell there are no creases where the old board is broke, it all looks and feels really good. to tell you the truth i am surprised that it is still this good, but it is.
Old Jul 11, 2009 | 05:16 PM
Let me know what you want for it. You are welcome to email me. sdl40@yahoo.com
Old Jul 13, 2009 | 09:21 AM
1Aauto's Avatar
Former Sponsor
Yes it can,that's what this kit is for.
Camaro Headliner Scrape and Recover Kit
Old Jul 21, 2009 | 10:30 PM
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: T5 WC
email sent
morrow
Jan 13, 2024 12:29 PM
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
