how do I know if my seatbelts work?
Old Aug 28, 2009 | 08:30 PM
Checkerbelly's Avatar
Other than the obvious?! I have a 1985 camaro, and I can yank and yank on them and they don't cinch up. I'm wondering how I know they'll stop me in an accident. How much work/money am I into if I replace them?
Old Aug 29, 2009 | 11:11 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: how do I know if my seatbelts work?
I believe the way they are designed, it's takes quite an abrupt force to lock them - more abrupt than one can generally get out of a "yank". However, you can swap in 4th gen belts if you are concerned without a ton of effort. Redo your headliner at the same time (since it has to come out anyway) and kill 2 birds with one stone.
Old Aug 29, 2009 | 11:17 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
The car has to be in motion for it to work properly.
The take up reel in the headliner has a weight that works with inertia and engages a brake. If you step on the brake and lean forward, that weight should stop the seat belt from moving - it doesn't take a whole lot of speed to check this out.
Old Aug 30, 2009 | 12:52 AM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
slam into a pole at 10mph :P
Old Aug 30, 2009 | 11:04 AM
Alright, thanks guys. (not you, Chevy8588 ) I'll check it out.
Old Aug 30, 2009 | 12:03 PM
Chevy8588's Avatar
lol, sorry, couldnt resist
Old Aug 31, 2009 | 03:08 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
I believe there was a recall on seatbelts in '85... not sure what the reason for it was.
Old Aug 31, 2009 | 03:16 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
There's a couple of threads on it...
https://www.thirdgen.org/forums/inte...lt-recall.html
https://www.thirdgen.org/forums/tech...l-84-90-a.html
Old Aug 31, 2009 | 10:46 PM
Zerocyde's Avatar
Car: 88 Camaro
Engine: 416 Stroker LS
Transmission: Magnum F
Axle/Gears: 4.11
Good thread, I was wondering the same.
Old Sep 9, 2009 | 01:16 PM
Oooh! Thanks for the heads-up.
Old Sep 9, 2009 | 02:23 PM
greatpumpkin_68's Avatar
Car: 1987 IROC & 1968 Nova
Engine: 5.0 TPI & 350
Transmission: 700R4 & powerglide
the seat belts in my iroc tighten up on me when i take off quickly from a dead stop. i then have to try to lean back even farther and pull the belt to loosen it back up a little. is that normal??
Old Apr 20, 2011 | 10:25 AM
dsboys21's Avatar
Car: 1988 Camaro
Engine: 2.8L V6
Transmission: Automatic
Good post. I had the same question. I tried to yank on the lap belt but it did not latch. i will try it in motion today.
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
