help with gage cluster bulbs change them to leds
Old Sep 7, 2009 | 09:42 PM
dustins92camaro's Avatar
i have a 92 camaro rs and i want to change the bulbs in the gage clust the and the gear shift to green and i want them i be led bulbs and i dont know wich one to get like what size i found a website it call super bright leds but i need to know wich ones to get and also for the map light and dome light i want to be led to and also green so can u help me out
Old Sep 7, 2009 | 10:13 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
Re: help with gage cluster bulbs change them to leds
194a for the cluster, dome light is a festoon, and map lights should be 194a as well
Old Sep 7, 2009 | 10:16 PM
can you find the ones on superbright leds cuz i cant find them there probly right i front of my face and i want them green and bright
Old Sep 7, 2009 | 10:39 PM
can you put a 12v in it for the dash lights map lights and dome light and gear shift light
Old Sep 7, 2009 | 10:46 PM
Chevy8588's Avatar
yea.... car electrical is all 12 volt DC..... they are all there under 12 volt car bulbs.. read the descriptions, 194's are wedge types and festoons are well.. festoons lol
Old Sep 7, 2009 | 10:55 PM
lol ok so the neowedge will work for the cluster lights and the fstoons will work ofr the dome light and the wled x4 qill work for the map lights im also getting some leds for the floor so it will light up the long tubes and going to light up the inside of my car lol can i put a touchscren radio in my car cuz i want to but i thing it will hit the molding piece around the gage cluster do u know if i can
Old Sep 7, 2009 | 10:58 PM
so the weld x4 will work for the map lights and the festoons with work for the dome light and the NeoWedge will work for the gage cluster right im going to get the inside of my car lit up with some led strips to put on the floor and also can i put a touchscreen radio in it cuz i think it with hit the molding around the gage cluster do u know
Old Sep 7, 2009 | 11:15 PM
Chevy8588's Avatar
a flip out SHOULD clear, but the shear length of the radio may be too long for the actual radio hole
Old Sep 8, 2009 | 07:37 AM
yea they said u have to modify it and put there braket in do the have spacers u can put in so they wont hit it
Old Sep 8, 2009 | 11:13 AM
mmm88TA's Avatar
Engine: 5.0 TPI
Transmission: TH700R4
Axle/Gears: 3.43 posi
http://www.v-leds.com/Exterior-LED/C...-p4481039.html
these are the 194's I got for my trucks dash and it turned out great, I used superbrights in the past but there bulbs burnt out very quickly (within 5 months).I've had my V-leds installed for almost a year now. I'm planning on getting some red led's for my trans am's dash.
Old Sep 8, 2009 | 05:05 PM
can i use the 44 mm or 42 mm festoon bulb in my stock dome holder thing
Old Sep 8, 2009 | 10:03 PM
mmm88TA's Avatar
Engine: 5.0 TPI
http://www.sylvania.com/ConsumerProd...RG-Results.htm
here's a link that tells you what every bulb in your car is.
Old Sep 8, 2009 | 10:05 PM
i wont let me view it there was an error it says
Old Sep 8, 2009 | 10:25 PM
mmm88TA's Avatar
Engine: 5.0 TPI
Dome light
211-2
so per the superbright cross reference guide it looks like 211= 4410 (44mmx10)
I'm just going by what their site says so this may or may not be correct.
sylvania fittment guide
http://www.sylvania.com/ConsumerProd...de/default.htm
superbright cross-reference
http://www.superbrightleds.com/bulb_cross.htm
VLeds 211 bulbs
http://www.v-leds.com/211-LED/c122265-1-2/
Old Sep 8, 2009 | 11:32 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
The best one for the dome lense is the first two in the 211 link.Dont even bother with the smaller ones.You want at least 30+ LEDs to illuminate the int.
GTAman
Mar 15, 2019 11:40 AM
Eric2ndGen
Nov 5, 2015 01:51 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Irocohio
Aug 12, 2015 08:03 AM
