New Cluster
Old Oct 26, 2009 | 02:07 PM
19Chevrolet84's Avatar
Car: 1984 Berlinetta,'82 and '86 Camaro
Engine: Rebuilt 350
Transmission: Automatic. =[
Axle/Gears: Stock
New Cluster
I just picked up an Instrument cluster from the local U-pull it for my 86 Camaro... The new one has a tach and my car doesn't... Will this plug right up? or are there more headaches?
If already posted, sorry, please link me.
Old Oct 26, 2009 | 10:21 PM
toomany's Avatar
Re: New Cluster
https://www.thirdgen.org/gauges
Should be plug and play after you replace some sending units.
Old Oct 27, 2009 | 04:36 PM
Engine: Rebuilt 350
Axle/Gears: Stock
Re: New Cluster
Thats about the 145 speedo, i picked up one from an 86... same as mine, only goes to 85 but has a tach and other gauges... Can i change the speedo and odometer from mine and plug it right in with the other cluster?
Old Oct 27, 2009 | 05:50 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: New Cluster
If you have 'idiot' lights in your car, regardless of the mph of the speedo, you'll need to swap some sending units. Hopefully, you're swapping V8 to V8 or V6 to V6.
JamesC
Old Oct 27, 2009 | 06:11 PM
Engine: Rebuilt 350
Axle/Gears: Stock
Re: New Cluster
It's from a V6 into a V6 for a couple of months, then I'm putting in a 350... More headaches to look forward to? I don't have my heart set on this cluster... it was cheap anyways... Will the tach work even though its a gas gauge there?
Old Oct 29, 2009 | 05:41 AM
Engine: Rebuilt 350
Axle/Gears: Stock
Re: New Cluster
anyone?
Old Oct 29, 2009 | 07:17 AM
JamesC's Avatar
Re: New Cluster
You might reread the link that toomany posted above.
JamesC
Old Oct 29, 2009 | 11:40 AM
toomany's Avatar
Re: New Cluster
The car is already setup (wiring) for the good (145mph, tach, etc) gauges, regardless if it came from the factory with only the gas gauge and speedo. You can mix and match gauges to your hearts content. As long as they have the correct sending units feeding them (sending units for gauges, not idiot light sending units) they will work.
If you plan on swaping to a v8 down the road, you will need a tach from a v8 car. The v6 and v8 tachs have differnt resistances. I made a post about it asking some questions, I believe it was in the electronics board. I ended up coming across the correct tach so I didn't need to change the resistance.
Elephantismo
Feb 13, 2019 12:51 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
James Sutton
Sep 23, 2015 02:18 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
