need advice: redoing visors
Car: 1987 IROC & 1968 Nova
Engine: 5.0 TPI & 350
Transmission: 700R4 & powerglide
the visors in my 87 iroc are in sad shape.. so last night i took one out and started cutting the thread that was holding it together. i plan on using all of the old stuff as patterns for the new.. my question is this: what do you suggest i use to replace the old worn out 'cardbaord' that wraps around the wooden part?? it needs to be thin enough to sew through and be able bend without creasing. has anyone done this or have ideas??? thanks!
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: need advice: redoing visors
Corrugated sheet paper is what i would use.If you hand stitch them, like i did mine.The thinner the better, but i re-used the orginals though.
yeah.. mine are too far gone to save. how did yours turn out with the hand stitching and all??
1992 Trans Am
May 10, 2023 07:19 PM
Rob P
Aug 21, 2001 03:31 PM
