Another speedometer question.
Old Dec 6, 2009 | 06:06 PM
MrPhotographer0's Avatar
Car: 1984 Camaro Sports Coupe
Engine: 355 chev
Transmission: none at the time
Axle/Gears: stock 10bolt v6 gears
I dont think any of the others answer my question.
I have an 84 camaro, and the speedometer clicks verry rapidply, and catches on every so often and flies up to whatever MPH. I've only driven it in the yard,so it hasnt been too fast.
I pulled the cluster today, and looked at the cable, i dont think its too bad, but i didnt pull it out. it spins when you drive it without the cluster, so i think its something with the speedo. Whats a way to test it?
Old Dec 6, 2009 | 06:31 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Another speedometer question.
Spinning and spinning consistently are two different stories. I'd pull the cable and clean both it and the cable housing of 20+ years of grunge. The following link, may be helpful if you haven't already viewed it:
https://www.thirdgen.org/forums/inte...eedo-woes.html
JamesC
Old Dec 7, 2009 | 09:23 AM
1Aauto's Avatar
Former Sponsor
If it's bouncing all over the place it's more than likely the cable.I'd replace that first.It should fix the issue.
Old Dec 7, 2009 | 06:43 PM
Engine: 355 chev
i think its the ends in it, cause it works if you hold pressure on the cable to the speedo.
bad ends probally..
Now that i got that diagnosed, when i put the cluster back in, i got the fuel gauge reading in the middle, vertically... any ideas?
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
Ian Irvine
Sep 4, 2015 08:08 AM
